Raised Spindle - What a mess
3 years 6 months ago #269626 by Jeff in Wa
File Name: PrintNC.zip
File Size:1.37 MB
Thank you Tommy...  Attached is my config
In response to your comments, I don't recall setting any spindle height when I first set up the machine.
I have a limit switch at the top of Z, and set the min / max limits in the .ini file
I have absolutely no idea where I would change the spindle height beyond this
Thanks for looking at this for me
3 years 6 months ago #269627 by tommylight
I do not think it is the spindle height causing issues, the probing is, it has to be told to go lower or the probing offset is still the old one hence the spindle cutting air.
Still i might be off as it's been quite a while since i have done anything mill related.
Thank you for not taking my response the wrong way.
3 years 6 months ago #269631 by Jeff_in_Wa
Tommy, maybe you are telling me what the issue is... Where is the probing offset stored? Maybe this is as simple as clearing that offset. I just don't know how that is stored.
3 years 6 months ago #269642 by Jeff_in_Wa
(Solved)
I went back to the Fusion 360 post and see something I haven't seen before in my posts...
G43 Z15. H10
This line is looking for tool compensation... I don't have any compensation in my tool file, so I don't know why this caused the issue. But, I changed the line to G0 Z15. F500. and my machine works again!!!!!!!!!!!
The following user(s) said Thank You: tommylight, ikkuh
Moderators: newbynobi, HansU
Time to create page: 0.063 seconds
