Spindel Load Bar wird nicht angezeigt beim verknüpfen mit Hal-Pin
2 years 5 months ago #300679 by Ludwig
File Name: LinuxcncSt...inal.txt
File Size:9.55 KB
2 years 5 months ago #300680 by Aciera
./spindle_load.hal:4: Ini variable '[HMOT]CARD0' not found.
Looks like you might be missing the card information in your ini file:[HMOT]
CARD0=<your_card_here>
As an alternative you could also start linuxcnc with the relevant line in 'spindle_load.hal' commented out and then look in the 'halshow' tool for the correct pin name and just use that instead of the ini lookup format you have now.
2 years 5 months ago #300683 by Ludwig
Hello Aciera,
yes, that was the problem.
net analog3 <= hm2_5i24.0.7i76.0.0.analogin3 => spindle_load.bar_spindle_load
Now the spindle load bar is displayed.
2 years 5 months ago #300684 by Ludwig
2 years 5 months ago #300685 by Ludwig
First many thanks for your quick help.
Now I have the problem that the analogin0, analogin1, analogin2 and analogin3 give no feedback (e.g 24V, 10V or any input),
but for this I will open another topic.
Again thanks a lot
Ludwig
Moderators: newbynobi, HansU
Time to create page: 0.119 seconds
