found an error
1 year 3 weeks ago #336012 by Moutomation
found an error was created by Moutomation
Hello,
Is there a solution to this problem?
1 year 3 weeks ago #336016 by Moutomation
Replied by Moutomation on topic found an error
This error occurs when we select the automatic G code file at the first startup from the gmoccopy settings.
1 year 3 weeks ago #336023 by Aciera
Replied by Aciera on topic found an error
Are you using master? If so you might have to update as a fix for such an issue was merged here:
github.com/LinuxCNC/linuxcnc/pull/3516
1 year 3 weeks ago #336026 by Moutomation
I use ethercat
1 year 3 weeks ago #336031 by Moutomation
I am using pi5, I could not find this file python_plugin.cc
1 year 3 weeks ago - 1 year 3 weeks ago #336032 by Aciera
I'm not familiar with pi installations but you could try these modifications to gmoccapy which also fixed the problem for me:
github.com/LinuxCNC/linuxcnc/pull/3511/files
[edit]
Without rebuilding you will need to modify 'gmoccapy' in the /bin folder.
Last edit: 1 year 3 weeks ago by Aciera.
The following user(s) said Thank You: Moutomation
Moderators: newbynobi, HansU
Time to create page: 0.367 seconds
