Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
  • Muzzer
  • Elite Member
  • Elite Member
21 Nov 2025 21:22 #338923 by Muzzer
I haven't used my gmoccapy lathe installation for perhaps 18 months due to working on other machines. At last use I was having problems with Andy Pugh's macros (something to do with needing Python 3?) and I'd struggled to finally get it to the point of working as it was (some problem with the RT kernal, which I had to change).
Although I haven't changed anything in the meantime, when I try to run gmoccapy, I now get errors and it bombs out. It seems to be something to do with the 5i25 possibly not loading if I understand the error message.
I'm planning to install the latest version of Linuxcnc and gmoccapy, so I'm not actually focusing on trying to rectify the above problem but the report file lists some of the components installed in the current system.
My question is - if I create a fresh Linux / Linuxcnc installation, what else would I need to port across to get it running? I'm thinking the hal and ini files for starters but is there anything else? Furthermore, are there any additional entries I'd need to put in the files? I think I saw a post mentioning some graphics-related additions to the ini or hal files when I was trawling through the forum yesterday but obvs I can't find it again. It's possible it was actually in the Probe Basic area of the forum - a version I previously set up but decided to stick with gmoccapy.
I'd be very grateful for any guidance to point me in the right direction!
File Name: linuxcnc.r...1-21.txt
File Size:5 KB
File Name: Bantam_v1_...1-21.hal
File Size:10 KB
File Name: gmoccapy_l...1-21.ini
File Size:8 KB
22 Nov 2025 00:53 - 22 Nov 2025 01:04 #338936 by unknown
Replied by unknown on topic Updating from LINUXCNC - 2.8.4-23, Mint 20.3
After looking at the error message it seems that this would be an issue for PCW to advise on. Maybe corrupted firmware, just a blind guess.
I know its generally frowned upon but the issue seems to be with the 5i25 card so.........
Maybe starting a new thread under driver boards referencing hm2/hm2_5i25.0: Module Descriptor 1 (at 0x044c) has invalid ClockTag 255, may yield a better answer, as it would seem to be more of an issue with the hardware rather than the UI. So it might be best to put off upgrading until this issue is resolved.
For the interim, if not all ready attempted, it may be worth cleaning the contacts of the card and reseating the card. I can't say whether or not this would resolve the issue.
Last edit: 22 Nov 2025 01:04 by unknown.
The following user(s) said Thank You: Muzzer
22 Nov 2025 01:17 #338940 by rodw
Really all you need to port across is your ~/linuxcnc folder
22 Nov 2025 02:08 #338945 by tommylight
Replied by tommylight on topic Updating from LINUXCNC - 2.8.4-23, Mint 20.3
The fan in my mom's decided to run at full speed one day,
Do you mean PC?
Back on topic:
-Power off the PC, unplug the power cord, wait 2-3 minutes
-Open the PC, pull out the Mesa 5i25
-Use an old clean cotton t-shirt to clean the contacts on the board, mind the parts near it, use a bit of force while moving back-forth on the contacts only
-Use an old clean toothbrush to clean the PCI slot on the PC, you can use a bit of alcohol on the brush
-wait 15 minutes if alcohol used, if not plug in the Mesa board
-insert the power cord, power on the PC
If it still does not work, try another PCI slot.
If it still does not work, enter the PC's BIOS and see if it has an entry for automatic assignment of resources, set it to manual, save reboot, test again.
The following user(s) said Thank You: Muzzer, unknown
  • Muzzer
  • Elite Member
  • Elite Member
22 Nov 2025 11:58 #338966 by Muzzer
Many thanks for the helpful suggestions! Notwithstanding the ever present Domestic Manager and her task list, I will have a go at those suggestions.
  • Cleaning and reseating the connectors sounds like a good plan. As you say, software doesn't simply evolve of its own accord. My mobo has only one ISA slot.
  • I have a spare SSD, so will do the install on that, leaving the existing system untouched.
  • "Really all you need to port across is your ~/linuxcnc folder" - I will look into this. Presumably that folder contains config data rather than executables etc.
  • If I'm still struggling with the 5i25 bit, I'll post a more focused query and perhaps PCW will be able to point me in the right direction.
Thanks again.
22 Nov 2025 12:18 #338967 by unknown
Until the issue with the 5i25 is sorted no amount of reinstalling Linuxcnc is going to fix the issue.
It's quite apparent that the config was working before. What is stopping it now from working is the error with 5i25.
It's akin to trying to get a car going by replacing the engine when the ROM in the ecu is bad.
  • Muzzer
  • Elite Member
  • Elite Member
22 Nov 2025 17:20 #338983 by Muzzer
Progress has been made. I opened up the mini ITX PC and examined the 5i25 assembly. This is a Jetway mobo with a single PCI-E slot. I had fitted an adaptor (PCI-E to full size PCI) and a PCI extension ribbon cable to connect the 5i25 which sits parallel to the mobo. This was the root of the problem, as the adaptor board wasn't seated properly. The mechanical assembly isn't ideal, so I will need to address that to avoid a repetition in the future.
gmoccapy now works as it did previously, so I can now move on to installing a new SSD with the current version of Mint and LCNC. I will then tackle the config files etc. Watch this space.....
  • Muzzer
  • Elite Member
  • Elite Member
22 Nov 2025 22:01 #339000 by Muzzer
Yes, I used the official LinuxCNC ISO. I see what you mean about XFCE, in contrast to the previous Mint GUI.....
Had a few problems installing it, which may have been due to using a 256GB UFD. Changed to a 16GB and it went well, whether that was the problem or not.
Now I have a functioning OS, I will have a go at reinstituting gmoccapy.
22 Nov 2025 23:56 #339010 by unknown
There's always the possibility of installing MATE, but unfortunately the Debian setup of the Menus and panels isn't as nice as Mint's setup.
23 Nov 2025 16:22 #339059 by unknown
On the lower panel one of the icons is search, although it maybe just be an application search, either way it's quite easy to customise, right clicking on a panel allows you to add, delete or modify icons.
Moderators: newbynobi, HansU
Time to create page: 0.317 seconds
