Can't read gcode text in dark mode when editing.
5 months 4 weeks ago - 5 months 4 weeks ago #346119 by TheTinkeringMechanic1
How do I tell what one it is?
Last edit: 5 months 4 weeks ago by TheTinkeringMechanic1.
5 months 4 weeks ago #346130 by HansU
You could post your INI-file, a screenshot or whatever command you use to start your G-code editor.
5 months 4 weeks ago - 5 months 4 weeks ago #346135 by TheTinkeringMechanic1
2.9.2
I press this to enter the editor within Linuxcnc.
I have changed the editor in the ini from gedit to mousepad with no change.
5 months 4 weeks ago #346140 by HansU
You probably run Gmoccapy 3.4.6.
I suggest to update LinuxCNC to the latest version, then you will find a new setting called "G-code theme" where you can select another theme for the G-code.
5 months 4 weeks ago #346145 by TheTinkeringMechanic1
Thank you. This brings up yet another issue, I have been trying to update but I don't believe I have a good repository. I keep getting an error saying the address doesn't have a release. I have attempted several different locations And I entered them into synapse. But I must be doing something wrong.
5 months 3 weeks ago #346188 by TheTinkeringMechanic1
It appears I'm on my own... again. So far nothing worked to get a repository to update LinuxCNC. So I said f-it and completely deleted the partition and reinstalled linuxcnc completely from scratch. I am gad I did.  The new installation resolved several issues. Most importantly, the editor in Linuxcnc that nothing I tried worked to get it resolved, is now resolved.
Moderators: newbynobi, HansU
Time to create page: 0.175 seconds
