Reading/Setting Backlash Compenstaion
  • electrosteam
  • Topic Author
  • Premium Member
  • Premium Member
30 minutes ago #350592 by electrosteam
Reading/Setting Backlash Compenstaion was created by electrosteam
Hobby, Gmoccapy 2.9.4, RPi4, old turret mill, 32 mm leadscrews, stepper motors, backlash up to 130 microns.
Backlash compensation set to 100 microns.
No problem producing good general-purpose parts.
But, current job has a central bore and two sides, Upper and Lower, requiring inversion of the part midway.
The Upper and Lower have a visible offset in the vertical join, not operationally a problem, just visible and perhaps 50 microns.
Tracking down all the usual suspects, but my thoughts turned to what the backlash compensation is doing.
Is there any way of observing and/or setting the backlash compensation ?
Good practices to manage the compensation ?
I will try installing a 123 block on the table at a known position.
Set Home at that position, and Home at switch-on only in X+ and Y+ directions.
Then Touch-off in the bore only in X+ and Y+ directions for the Upper, X- and Y- on inversion for the Lower.
The new Forum looks good to me.
Short note: I tried to post the same subject on 30Oct26, now lost.
John.
Moderators: newbynobi, HansU
Time to create page: 0.049 seconds
