Open some examples and see the order of the subroutines, Workpiece and ToolChange must ALWAYS be before a cut command.SteveT wrote: ...I keep getting the following error.
G-Code error in ncam.ngc
/home/steven/linuxcnc/configs/my-mill_4axis/ncam/scripts/ncam.ngc:
Named parameter #<_tool_usage> not defined
Clive s wrote: ...Would you mind giving me the command line to edit the launcher to be able to use Lathe instead of mill.
This is my Ncam working command line for Mill ncam -i /home/clive/linuxcnc/configs/baz_test/baz_test.ini
