- Thank you received: 217
I Just come from to understand the problem. This is this post forum.linuxcnc.org/nativecam/43495-run-n...ithout-embeding-ncam of Tjtr33 that help to understand that the Nativecam Gcode generate is not the same that Linuxcnc can Run... so we have to had the new Ocode lib the basic magic M123 code that must be made available to Linuxcnc... After to just add this one line to the Ini file the Gcode is RunableI have try with ncam -t tab mode...and same problem the gcode failed in Linuxcnc..
So i have try integrate mode of Nativeme cam ncam -i on inifile and here Nativecam integrage mode have working gcod load in Linuxcnc. Very curious.
If i try to export Gcode from Nativecam integrate to Linuxcnc the gcode is good and runnable on Linuxcnc with embedded Nativecam only if load in file mode
