NativeCAM 2.0b — Python 3 & GTK3 port for LinuxCNC 2.9 / Debian 13 Trixie
6 months 2 weeks ago #345703 by axemas
The fix is now released in version 2.0b-1:
github.com/cnc-proton/nativecam-py3-gtk3/releases/tag/v2.0b-1
Download the new .deb and install it:
sudo apt remove nativecam
sudo apt install ./nativecam_2.0b-1_all.deb
This should resolve the python/python3 issue on Debian 12.
Please let me know if you run into any other problems.
Best,
6 months 2 weeks ago #345704 by axemas
Hi Surmetall,
Thanks for the link to Talla83's Discord — I actually know Peter's
videos, really good content. I will join the Discord, sounds like
a great place for quick technical feedback.
And I completely agree about keeping both channels alive. Forum for
long-term knowledge base where people can find solutions years later,
Discord for quick "I am at the machine, something does not work"
situations. Different tools for different needs.
Sorry to hear about your Beckhoff struggles. That is exactly the
kind of retrofit work where LinuxCNC really shines — replacing
expensive proprietary controllers. If I can help with anything
regarding the driver side, let me know.
Regarding the lathe polyline — still polishing a few things, then
I will push to GitHub. I will post here and ping on Discord when
it is ready for testing.
Best,
CNC Proton
The following user(s) said Thank You: COFHAL
6 months 2 weeks ago #345707 by COFHAL
Thanks>
now it looks like this error: ornocnc@tornocnc:~/linuxcnc/configs/MILLING MACHINE$ ncam -i MILLING MACHINE.ini -c mill -t
Error modifying ini file
a bytes-like object is required, not 'str'
/usr/bin/ncam:346: PyGTKDeprecationWarning: The keyword(s) "type, message_format" have been deprecated in favor of "message_type, text" respectively. See: wiki.gnome.org/PyGObject/InitializerDeprecations
dlg = gtk.MessageDialog(parent = None,
/usr/bin/ncam:346: PyGTKDeprecationWarning: The "flags" argument for dialog construction is deprecated. Please use initializer keywords: modal=True and/or destroy_with_parent=True. See: wiki.gnome.org/PyGObject/InitializerDeprecations
The following user(s) said Thank You: axemas
6 months 1 week ago #345718 by axemas
Thank you for testing! Found another Python 3 compatibility bug.
The function that modifies the ini file was still using old Python 2
API (io.BytesIO with str argument).
This will be fixed in the next release (2.0b-2) which I will push
to GitHub shortly.
By the way, there's a separate issue — your config folder has a
space in the name ("MILLING MACHINE"). LinuxCNC works with it, but
it can cause problems with some tools. Consider renaming to
"MILLING_MACHINE" for safety.
Best,
Axemas
The following user(s) said Thank You: tommylight, COFHAL
6 months 1 week ago #345775 by COFHAL
Now all these errors appear indicating that some strings are already in the ini file:
While reading from '<string>' [line 24]: option 'position_feedback' in section 'DISPLAY' already exists
error modifying ini file
While reading from '<string>' [line 37]: option 'program_extension' in section 'FILTER' already exists
While reading from '<string>' [line 71]: option 'halfile' in section 'HAL' already exists
While reading from '<string>' [line 94]: option 'tool_table' in section 'EMCIO' already exists
Source contains parsing errors: '<string>'
[line 291]: '= \n'
6 months 1 week ago #345785 by axemas
"Hi everyone,
Thank you all for testing the port and providing feedback! I've just pushed a few fixes to the repository (including the INI parsing errors and GTK deprecation warnings). github.com/cnc-proton/nativecam-py3-gtk3...vecam_2.0b-4_all.deb
Regarding Bug Reports:
As more people start using this port, it becomes harder to track individual errors and logs across forum pages. If you encounter a bug, a crash, or a specific error message, please report it via GitHub Issues here: github.com/cnc-proton/nativecam-py3-gtk3/issues
The forum is still the perfect place for general discussions, sharing ideas (like the Lathe Polyline!), and showing off your work. But keeping the technical bug reports on GitHub allows me to solve them much faster and keep the project organized.
Thanks for understanding and for your continued support!"
The following user(s) said Thank You: tommylight, besriworld, COFHAL, Surmetall, jjdege, Unlogic
Time to create page: 0.465 seconds
