Upgrade to Pathpilot 2
8 years 8 months ago #105479 by racedirector
Has anyone successfully upgraded to PP2? I am trying but it is not going well. PP2 has a totally different way of loading the ini, no longer is config.txt used but a python file intervenes. I mangled to get it started but it is soooooo slow, won't load everything on screen and won't reset.
I can't see much different in a standard Tormach ini file and my own but will persevere until someone has done the same thing.
If anyone has successfully completed the upgrade please do jump in....
Cheers
8 years 8 months ago #105525 by brianTruck
Replied by brianTruck on topic Upgrade to Pathpilot 2
I have been playing with it on a spare computer. Trying to get it into sim mode,no luck so far.
Brian
8 years 8 months ago #105548 by Millper1
Replied by Millper1 on topic Upgrade to Pathpilot 2
ctr+alt+s before picking machine config gets into sim mode
The following user(s) said Thank You: brianTruck
8 years 8 months ago #105554 by brianTruck
Thanks', worked perfect.
Brian
8 years 8 months ago - 8 years 8 months ago #105560 by racedirector
Replied by racedirector on topic Upgrade to Pathpilot 2
Well after some setbacks I actually have PP2 running my machine. I will document the process of moving from PP1 to PP2 sometime tomorrow so others can get it working. Not many actual changes required but PP2 now runs 2.8 pre under 64bit Mint Mate so any extras added to your PP install will need the 64 bit equivalents.
More tomorrow
Cheers
Last edit: 8 years 8 months ago by racedirector.
8 years 8 months ago #106262 by Jakemestre1
Replied by Jakemestre1 on topic Upgrade to Pathpilot 2
Hi Racedirector, any chance we could get your thoughts on the update? I'm struggling a bit. Thank you.
Jake
Time to create page: 0.178 seconds
