- Thank you received: 75
PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
- cncnoob1979
- Topic Author
8 years 7 months ago - 8 years 7 months ago #106860
by cncnoob1979
Replied by cncnoob1979 on topic PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
Hahah! That would so be my life!
I tried this with my full install of pp2 that I recently installed a few days ago from tormach.
I read you could and thought it was strange. It would not work for me so I thought they changed it.
Well then, I'll have to check it out again. What version are you on? 2.0/.1/.2?
Edit;
Can you also halshow? On a clean install?
Edit;
Last edit: 8 years 7 months ago by cncnoob1979.
8 years 7 months ago #106861
by narrobb
Replied by narrobb on topic PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
I am on 2.0.1, 2.0.0 works the same.
The python source code for the MDI box also have halshow as one of the options, but I never tried it myself. Will check it out.
So you saying ADMIN HALMETER did not work for you?
If you want to see all the commands accepted after ADMIN, check ui_common.py file located in python here: /home/operator//v2.0.1/python
around line 200 in the file.
- cncnoob1979
- Topic Author
8 years 7 months ago #106862
by cncnoob1979
Thanks I'll have to check it out.
I also just typed ADMIN in the midi box and looked at available commands in the status text.
I've been getting pretty familiar with that python file I'll check it out tonight.
I did try admin halmeter (and others) as I recall and no it did not work for me. But it is possible that I broke something before I tried; I've been deconstructing path pilot because I want to export the GUI and separate it from PP2.
My understanding is that the images are copy protected tho. So that will have to be redone.
That's how I figured out where the development "repo" is located.
8 years 7 months ago #106863
by narrobb
admin command on status only shows part of it, they don't show the advance options.
I think you right about the images.
You mean you want to use PP but with different GUI? All the glade files are visible as well, and you can trace them easily and modify. Will be good to have more than one GUI option
- cncnoob1979
- Topic Author
8 years 7 months ago #106864
by cncnoob1979
I mean I want to pull the GUI from pp and use it on a normal install of linuxcnc.
Just keeping the GUI design and capabilities. Create another axis;gmoccapy or gscreen.
8 years 6 months ago #108942
by dinkata
Replied by dinkata on topic PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
please tell how to make launcher in PathPilot 2. for non Tormach machine 5i25+7i77 ?
Sim work ctrl+alt+s .
Time to create page: 0.178 seconds
