Pathpilot and Mesa 7I92 + 7I76
  • Robi63
  • Topic Author
  • Junior Member
  • Junior Member
8 years 7 months ago #108265 by Robi63
Pathpilot and Mesa 7I92 + 7I76 was created by Robi63
Hello!
In Pathpilot 2.0 there are files (Mesa Folder) tormach_lathe_7i92.bit and other files for the 7I92 card.
Do you think this indicates that you can use 7I92 instead of 5I25?
Roberto
8 years 7 months ago #108268 by PCW
Replied by PCW on topic Pathpilot and Mesa 7I92 + 7I76
I believe that's true (with Tormachs breakout board)
To use a 7I76 you would need non-standard (for Tormach) hal/ini/bit files
  • Robi63
  • Topic Author
  • Junior Member
  • Junior Member
8 years 7 months ago #108306 by Robi63
Replied by Robi63 on topic Pathpilot and Mesa 7I92 + 7I76
I had seen everything easy (You woke me from the dream).
However
File 7i92_7i76.bit (exists).
Pathpilot supports this connection.
File ini requires this addition. (Toprmach file)
-# These items make the "base" Tormach lathe INI into an SlantPro 15L via Mesa 7i92 card
-[INI_CONFIG]
-BASE_INI_FILE = tormach_lathe_base.ini ( Mio.ini)
-[EMC]
-MACHINE = 15L-SlantPro
-[HOSTMOT2]
-DRIVER=hm2_eth
-BOARD=7i92
-DRIVER_PARAMS="board_ip=10.10.10.10 config= num_encoders=2 num_pwmgens=1 num_3pwmgens=0num_stepgens=3 enable_raw"
-BITFILE0=mesa/tormach_lathe_7i92.bit (7i92_7i76.bit )
File hal here is complicated.
I'm still dreaming :)
Roberto
8 years 2 months ago #115957 by gantarone
Replied by gantarone on topic Pathpilot and Mesa 7I92 + 7I76
someone tried the 7i76e on Pathpilot 2?
8 years 2 months ago #115958 by tecno
Replied by tecno on topic Pathpilot and Mesa 7I92 + 7I76
That is an interesting question that I would also like to here about.
Time to create page: 0.684 seconds
