Mach3 style hotkey for feed overdrive , jog speed
  • tivoi
  • Topic Author
  • Senior Member
  • Senior Member
8 years 3 months ago - 8 years 3 months ago #113375 by tivoi
Mod code in tormach_mill_ui.py
# F11 key for incr feedrate
if kv == gtk.keysyms.F11:
self.feedrate_override_adjustment.set_value(self.feedrate_override_adjustment.get_value()+5)
return True
# F11 key for decr feedrate
if kv == gtk.keysyms.F10:
self.feedrate_override_adjustment.set_value(self.feedrate_override_adjustment.get_value()-5)
return True
# bracketleft key for decr jog speed
if kv == gtk.keysyms.bracketleft:
if self.jog_speed_adjustment.get_value()<5:
self.jog_speed_adjustment.set_value(self.jog_speed_adjustment.get_value()-0.1)
else:
self.jog_speed_adjustment.set_value(self.jog_speed_adjustment.get_value()-1)
return True
# bracketright key for incr jog speed
if kv == gtk.keysyms.bracketright:
self.jog_speed_adjustment.set_value(self.jog_speed_adjustment.get_value()+0.1)
else:
self.jog_speed_adjustment.set_value(self.jog_speed_adjustment.get_value()+1)
return True
Last edit: 8 years 3 months ago by tivoi.
The following user(s) said Thank You: emptyhb
8 years 3 months ago #113395 by tommylight
Replied by tommylight on topic Mach3 style hotkey for feed overdrive , jog speed
F11 and F12 keys are used for spindle speed increase or decrease in Linuxcnc.
I do not know about PP as i never used it.
Thank you, might be useful to others.
  • tivoi
  • Topic Author
  • Senior Member
  • Senior Member
8 years 1 month ago #117276 by tivoi
PP + hotkey + customizer keyboard
The following user(s) said Thank You: Jedi
Time to create page: 0.509 seconds
