Change these
copy the haltcl file to /home/operator/tmc/bin/ and change the first two lines to
#!/usr/bin/tclsh8.6
load /home/operator/repos/tormach_linuxcnc/linuxcnc/tcl/hal.so
Add the folloing three lines to the end of .bashrc to run hal commands from a shell (sorry, one existing file is modified)
export LD_LIBRARY_PATH="/home/operator/tmc/lib"
export PATH="/home/operator/tmc/bin":$PATH
export LINUXCNC_RTLIB_DIR="/home/operator/tmc/rtlib"
to
#!/usr/bin/tclsh8.6
load /home/operator/tcl/hal.so
Add the following three lines to the end of .bashrc to run hal commands from a shell (sorry, one existing file is modified)
export LD_LIBRARY_PATH="~/tmc/lib"
export PATH=~/tmc/bin:~/tmc/scripts:$PATH
export LINUXCNC_RTLIB_DIR="~/tmc/rtlib"
that should do the same thing
I haven't checked it but if that was all you had to do that change to PATH should be all that's needed
