PathPilot V2 with 7I80DB-16 + 7i76
7 years 7 months ago - 7 years 7 months ago #128030 by mjoconr
Thats a good idea, I’ll give that a try this morning.
As has been said PP is just a UI, and any issues with getting it going will always be a LinuxCNC issue.
I’m only using PP because it has a nice interface. I actually hope to create my own UI. Just need to learn more first.
Mike
Last edit: 7 years 7 months ago by mjoconr.
7 years 7 months ago #128038 by mjoconr
So using a newer bit file has got me past first issue.
Now I think I have adjust the hal file to match the board.
see
'tormach_mill_mesa.hal:248: parameter or pin 'hm2_7i80.0.gpio.005.is_output' not found'
Starting LinuxCNC server program: linuxcncsvr Starting LinuxCNC IO program: io io started halcmd loadusr io started Starting HAL User Interface program: halui halcmd loadusr -Wn halui halui -ini /home/operator/tmc/configs/tormach_mill/tormach_1100-3_7i92.ini halcmd -i /home/operator/tmc/configs/tormach_mill/tormach_1100-3_7i92.ini -f tormach_mill_mesa.hal Note: Using POSIX realtime hm2: loading Mesa HostMot2 driver version 0.15 hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2 hm2_eth: 10.10.10.10 config=num_encoders=0 num_pwmgens=1 num_3pwmgens=0 num_stepgens=5 : Hardware address: 00:60:1b:10:00:50 hm2_eth: discovered 7I80DB-16 hm2/hm2_7i80.0: Smart Serial Firmware Version 43 Board hm2_7i80.0.7i76.0.0 Hardware Mode 0 = standard Board hm2_7i80.0.7i76.0.0 Software Mode 0 = io_spin Board hm2_7i80.0.7i76.0.0 Software Mode 1 = io_ana_spin Board hm2_7i80.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv hm2/hm2_7i80.0: 68 I/O Pins used: hm2/hm2_7i80.0: IO Pin 000 (J2-01): StepGen #0, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 001 (J2-14): StepGen #0, pin Step (Output) hm2/hm2_7i80.0: IO Pin 002 (J2-02): StepGen #1, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 003 (J2-15): StepGen #1, pin Step (Output) hm2/hm2_7i80.0: IO Pin 004 (J2-03): StepGen #2, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 005 (J2-16): StepGen #2, pin Step (Output) hm2/hm2_7i80.0: IO Pin 006 (J2-04): StepGen #3, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 007 (J2-17): StepGen #3, pin Step (Output) hm2/hm2_7i80.0: IO Pin 008 (J2-05): StepGen #4, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 009 (J2-06): StepGen #4, pin Step (Output) hm2/hm2_7i80.0: IO Pin 010 (J2-07): Smart Serial Interface #0, pin TxData0 (Output) hm2/hm2_7i80.0: IO Pin 011 (J2-08): Smart Serial Interface #0, pin RxData0 (Input) hm2/hm2_7i80.0: IO Pin 012 (J2-09): IOPort hm2/hm2_7i80.0: IO Pin 013 (J2-10): IOPort hm2/hm2_7i80.0: IO Pin 014 (J2-11): Encoder #0, pin Index (Input) hm2/hm2_7i80.0: IO Pin 015 (J2-12): Encoder #0, pin B (Input) hm2/hm2_7i80.0: IO Pin 016 (J2-13): Encoder #0, pin A (Input) hm2/hm2_7i80.0: IO Pin 017 (J3-01): StepGen #5, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 018 (J3-14): StepGen #5, pin Step (Output) hm2/hm2_7i80.0: IO Pin 019 (J3-02): StepGen #6, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 020 (J3-15): StepGen #6, pin Step (Output) hm2/hm2_7i80.0: IO Pin 021 (J3-03): StepGen #7, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 022 (J3-16): StepGen #7, pin Step (Output) hm2/hm2_7i80.0: IO Pin 023 (J3-04): StepGen #8, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 024 (J3-17): StepGen #8, pin Step (Output) hm2/hm2_7i80.0: IO Pin 025 (J3-05): StepGen #9, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 026 (J3-06): StepGen #9, pin Step (Output) hm2/hm2_7i80.0: IO Pin 027 (J3-07): IOPort hm2/hm2_7i80.0: IO Pin 028 (J3-08): IOPort hm2/hm2_7i80.0: IO Pin 029 (J3-09): IOPort hm2/hm2_7i80.0: IO Pin 030 (J3-10): IOPort hm2/hm2_7i80.0: IO Pin 031 (J3-11): Encoder #1, pin Index (Input) hm2/hm2_7i80.0: IO Pin 032 (J3-12): Encoder #1, pin B (Input) hm2/hm2_7i80.0: IO Pin 033 (J3-13): Encoder #1, pin A (Input) hm2/hm2_7i80.0: IO Pin 034 (J4-01): StepGen #10, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 035 (J4-14): StepGen #10, pin Step (Output) hm2/hm2_7i80.0: IO Pin 036 (J4-02): StepGen #11, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 037 (J4-15): StepGen #11, pin Step (Output) hm2/hm2_7i80.0: IO Pin 038 (J4-03): StepGen #12, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 039 (J4-16): StepGen #12, pin Step (Output) hm2/hm2_7i80.0: IO Pin 040 (J4-04): StepGen #13, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 041 (J4-17): StepGen #13, pin Step (Output) hm2/hm2_7i80.0: IO Pin 042 (J4-05): StepGen #14, pin Direction (Output) hm2/hm2_7i80.0: IO Pin 043 (J4-06): StepGen #14, pin Step (Output) hm2/hm2_7i80.0: IO Pin 044 (J4-07): IOPort hm2/hm2_7i80.0: IO Pin 045 (J4-08): IOPort hm2/hm2_7i80.0: IO Pin 046 (J4-09): IOPort hm2/hm2_7i80.0: IO Pin 047 (J4-10): IOPort hm2/hm2_7i80.0: IO Pin 048 (J4-11): Encoder #2, pin Index (Input) hm2/hm2_7i80.0: IO Pin 049 (J4-12): Encoder #2, pin B (Input) hm2/hm2_7i80.0: IO Pin 050 (J4-13): Encoder #2, pin A (Input) hm2/hm2_7i80.0: IO Pin 051 (J5-01): IOPort hm2/hm2_7i80.0: IO Pin 052 (J5-14): IOPort hm2/hm2_7i80.0: IO Pin 053 (J5-02): IOPort hm2/hm2_7i80.0: IO Pin 054 (J5-15): IOPort hm2/hm2_7i80.0: IO Pin 055 (J5-03): IOPort hm2/hm2_7i80.0: IO Pin 056 (J5-16): IOPort hm2/hm2_7i80.0: IO Pin 057 (J5-04): IOPort hm2/hm2_7i80.0: IO Pin 058 (J5-17): IOPort hm2/hm2_7i80.0: IO Pin 059 (J5-05): IOPort hm2/hm2_7i80.0: IO Pin 060 (J5-06): IOPort hm2/hm2_7i80.0: IO Pin 061 (J5-07): IOPort hm2/hm2_7i80.0: IO Pin 062 (J5-08): IOPort hm2/hm2_7i80.0: IO Pin 063 (J5-09): IOPort hm2/hm2_7i80.0: IO Pin 064 (J5-10): IOPort hm2/hm2_7i80.0: IO Pin 065 (J5-11): IOPort hm2/hm2_7i80.0: IO Pin 066 (J5-12): IOPort hm2/hm2_7i80.0: IO Pin 067 (J5-13): IOPort hm2/hm2_7i80.0: registered sysctl: cannot stat /proc/sys/net/ipv6/conf/eth0/disable_ipv6: No such file or directory hm2_eth: ERROR: Failed to execute '/sbin/sysctl -q net.ipv6.conf.eth0.disable_ipv6=1' Z-Bot ATC : HAL component : started 2019-03-07 16:46:26 Smart Cool: HAL component: started 2019-03-07 16:46:26 tormachheightgauge: starting USBIO : HAL component starting 2019-03-07 16:46:26 tormach_mill_mesa.hal:248: parameter or pin 'hm2_7i80.0.gpio.005.is_output' not found Shutting down and cleaning up LinuxCNC...
7 years 6 months ago - 7 years 6 months ago #131074 by mrichard
Everybody seems to get this wrong when trying to get PP2 to install. Please read Brianbone's thread from The Industry Arena forum. The key is to make the PP base file point to your .ini file. The following explains this.
I'd figure I would start a new thread for folks trying to upgrade from 1.9.x to PP 2.0 - and here are my thoughts and what I went through:
1. I had to change my motherboard because PP 2.0 didn't like my GPU which was an old GeForce 610 (Old mobo didn't have built in video). I probably could have figured it out, but I am no linux guru and couldn't even see anything on the screen - it was totally garbled. I ended up buying an old Gigabyte GA-41 with built in video, and it worked without any trouble (I wanted to still use my old E2200 dual core pentium chip that I had been using). I doubt most people will need to do this.
2. Please use a separate SSD drive, and unplug your PP 1.9.x drive for obvious reasons. Backup all settings in PP 1.9 "admin settings backup" save to thumb drive. this saves all your offsets and stuff.
3. PP 2.0 installs pretty easily from the thumb drive.
4. To get to the desktop, the Left Shift-Alt keys are supposed to work (it says so in the PP 2.0 operator_login script) but I couldn't get mine to work. So I hit Ctrl-Alt X to get to a terminal prompt. Then type in "mate-panel" This is the new desktop in PP 2.0. gnome is not installed.
5. Next go to system preferences - startup applications and deselect the PathPilot. This prevents the auto start of PP. This is important because now if PP errors out, it shuts down the computer and takes a long time to fix each error.
6. PP 2.0 still runs from the "operator_login" script. If you click that and run "in terminal" like before then you can debug it more easily.
7. When debugging, in PP 1.9.x you could look at the terminal screen to find your errors, now the terminal screen closes, so you have to open the pathpilotlog.txt which is located in the gcode folder in log files folder.
8. Also in PP 2.0, if you edit the tormach_1100-3.ini then PP 2.0 will RE-WRITE it upon any error. So instead I created a "novakon_mill_base.ini" file. Then I edited the "tormach_1100-3_specific.ini" file to point to the novakon_mill_base.ini file. This tricks PP into using the novakon file to build the new ini file in case of an error. So all edits to the ini file should be to the novakon_mill_base file. If anything messes up, you can delete the tormach_1100-3.ini file and PP 2.0 will create a new one from the mill base file.
9. Everything else is pretty similar to before. I posted all my novakon files that should get you going on a Pulsar.
10. To install Dropbox in the MDI window type "Admin dropbox" and it will prompt you to set that up.
11. Restore your old settings by "admin settings restore" and this will import your old tool table and settings.
*Just a side note: I had to re-write the Charge Pump code in the hal file. I am not sure why the old code worked in PP 1.9 but didn't in 2.0. I used PCW_Mesa's example somewhere in linuxcnc forums and now the charge pump works fine **
Attached Files Attached Files
File Type: txt tormach_1100-3_specific.ini.txt (150 Bytes, 3 views)
Last edit: 7 years 6 months ago by mrichard.
7 years 3 months ago #139022 by Derek240
Hi Mike
Did you ever get the 7I80DB working with PathPilot?
7 years 3 months ago #139043 by mjoconr
No I gave up, I did not (and still do not) know enough about the configuration of the HAL files to make the changes needed.
I'm working on getting the machine going with source code install in a seperate forum post right now.
7 years 3 months ago #139088 by Derek240
Ok Thanks for the reply.
Time to create page: 0.307 seconds
