- Thank you received: 28
Using PNCconf with PathPilot
- Vmax549
- Topic Author
7 years 3 months ago #139351
by Vmax549
Using PNCconf with PathPilot was created by Vmax549
Has anyone tried using PNCconf with PathPilot to help setup a new Config ??
TP
- pl7i92
- Thank you received: 358
7 years 3 months ago #139379
by pl7i92
Replied by pl7i92 on topic Using PNCconf with PathPilot
path pilot got nice presetups
so it may be only a view changes to a standard
go to the homepage
or get it from the tread here called pathpilot config
go to the homepage
- smgvbest
- Thank you received: 51
7 years 3 months ago #139415
by smgvbest
Replied by smgvbest on topic Using PNCconf with PathPilot
Are you looking to run PNCConf from PP or run it from a LinuxCNC build and copy the INI and HAL files to PP?
I've run pcnconf from pp install after coping all needed files to the ~/tmc directory.
after you create it you just need to map some of the pins over to the tormach pins so PP can work .
running halshow you can see all the tormach specific stuff ( not actually allow of it) then connect the pins over.
- Vmax549
- Topic Author
7 years 3 months ago #139420
by Vmax549
Replied by Vmax549 on topic Using PNCconf with PathPilot
Can you explain how to set up PNCconfig in PathPilot ?? I am setting up a 7i80 in PathPilot and it seems that PNCconf would be very handy to use.
Time to create page: 0.087 seconds
