Moving the Step/Dir spindle control to another port. 7i80
  • Vmax549
  • Topic Author
  • Platinum Member
  • Platinum Member
7 years 3 months ago - 7 years 3 months ago #139998 by Vmax549
I need to move teh spindle control (s/d) to another port J2 -> J3. The current stepgen on J3 is #04 and the stepgen on J3 port is #09.
I am under the assumption that I just need to change the HAL from every line that contains (board),0,stepgen,04 to (board)0,stepgen,09 and that should transfer everything over to port J3 ??
Am I close ??
(;-) TP
Last edit: 7 years 3 months ago by Vmax549.
7 years 3 months ago #139999 by PCW
Yes
( and you need to enable 10 stepgens )
  • Vmax549
  • Topic Author
  • Platinum Member
  • Platinum Member
7 years 3 months ago #140010 by Vmax549
OK I have seen that somewhere would it be in the HAL or INI file?
7 years 3 months ago #140011 by PCW
depends on how the files are structured
but it ends up in the "loadrt hm2_eth" command line
  • Vmax549
  • Topic Author
  • Platinum Member
  • Platinum Member
7 years 3 months ago - 7 years 3 months ago #140012 by Vmax549
OK it is in teh INI files but there are 3 ini where I find it at do I change all three files ??
7 years 3 months ago - 7 years 3 months ago #140016 by PCW
It can only be in one ini file
(at least only one that's actually used)
Last edit: 7 years 3 months ago by PCW.
  • Vmax549
  • Topic Author
  • Platinum Member
  • Platinum Member
7 years 3 months ago #140018 by Vmax549
Actually there are 3 INIs in PathPilot.
Base.ini
mill.ini
specific_Mill.ini
That line is in all 3 so I will try updated all 3 to make sure I get teh right one. That was what I did to change out the Card Name and bit file. So far that part worked. I think they have a fallback system in place.
(;-) TP
7 years 3 months ago #140021 by smgvbest
specific_mill.ini overrides the base.ini so you put all your customization's in that one
  • Vmax549
  • Topic Author
  • Platinum Member
  • Platinum Member
7 years 3 months ago - 7 years 3 months ago #140022 by Vmax549
OK That worked I now have a spindle outout from J3 pin 14.
Thanks Guys, It is starting to make a little sense now. NEXT is teh spindle encoder :unsure:
(;-) TP
