- Thank you received: 28
Moving the Step/Dir spindle control to another port. 7i80
7 years 3 months ago - 7 years 3 months ago #139998
by Vmax549
Moving the Step/Dir spindle control to another port. 7i80 was created by Vmax549
I need to move teh spindle control (s/d) to another port J2 -> J3. The current stepgen on J3 is #04 and the stepgen on J3 port is #09.
I am under the assumption that I just need to change the HAL from every line that contains (board),0,stepgen,04 to (board)0,stepgen,09 and that should transfer everything over to port J3 ??
Am I close ??
TP
Am I close ??
Last edit: 7 years 3 months ago by Vmax549.
7 years 3 months ago #139999
Replied by PCW on topic Moving the Step/Dir spindle control to another port. 7i80
Yes
( and you need to enable 10 stepgens )
7 years 3 months ago #140010
by Vmax549
Replied by Vmax549 on topic Moving the Step/Dir spindle control to another port. 7i80
OK I have seen that somewhere would it be in the HAL or INI file?
7 years 3 months ago #140011
depends on how the files are structured
but it ends up in the "loadrt hm2_eth" command line
7 years 3 months ago - 7 years 3 months ago #140012
by Vmax549
OK it is in teh INI files but there are 3 ini where I find it at do I change all three files ??
7 years 3 months ago - 7 years 3 months ago #140016
It can only be in one ini file
(at least only one that's actually used)
Last edit: 7 years 3 months ago by PCW.
Time to create page: 0.129 seconds
