Path Pilot and spindle encoder
  • Vmax549
  • Topic Author
  • Platinum Member
  • Platinum Member
7 years 3 months ago #140031 by Vmax549
Path Pilot and spindle encoder was created by Vmax549
In my Bit file for teh 7i80 there are 3 encoders 1,2,3 . I need to use #3 because it is on teh BOB that can read encoder indexes. The BOBs for 1and 2 encoders teh optis are not fast enough to read teh Index signal.
Lets me see if I have this correct. I have to set encoder = 3 in order to use encoder #3 but then I loose teh use of teh 6 pins for 1and 2 as I only need 1 encoder. And I cannot just set teh encoders =1 because then I would have to use teh BOB with slow opti.
OR I need a new bit file that only defines 1 encoder on teh port that has fast opti.
Is that about right ??
Also teh reference code I found is all for LPT versions not a Mesa card version and it appears different. Does anyone know of a reference to teh code needed for a 7i80 to install teh spindle encoder in PathPilot ??
(;-) TP
7 years 3 months ago #140032 by PCW
Replied by PCW on topic Path Pilot and spindle encoder
You do not lose the ability to use any encoder pins as inputs if you enable
all encoders (0,1,2 in this case)
You do lose the ability to set the encoder pins to output mode
  • Vmax549
  • Topic Author
  • Platinum Member
  • Platinum Member
7 years 3 months ago #140138 by Vmax549
Replied by Vmax549 on topic Path Pilot and spindle encoder
OK I have teh spindle encoder patched in I believe I still have to test it tommorow with an MPG I have here. I should be able to see teh encoder signals somewhere (;-)
(;-) TP
Time to create page: 0.045 seconds
