Lincurve and Pathpilot
  • davidimurray
  • Topic Author
  • Senior Member
  • Senior Member
7 years 3 months ago - 7 years 3 months ago #140312 by davidimurray
Lincurve and Pathpilot was created by davidimurray
After getting PP 2.2.4 to boot up. I've now got as far as getting a lathe setup working. I've moved various bits of my old HAL files over to get to the point where the axis, limits etc are working from the parallel port.
Now looking at the spindle, i used lincurve to get goo spindle speed control. I've tried copying lincurve.ko into the rtlib folder (as others have done successfully), but when i try and boot I got the following errors in the log file.
Any thoughts/help/ideas to resolve this much appreciated
lincurve: dlopen: /home/operator/tmc/rtlib/lincurve.so: cannot open shared object file: No such file or directory Starturn.hal:15: waitpid failed /home/operator/tmc/bin/rtapi_app lincurve Starturn.hal:15: /home/operator/tmc/bin/rtapi_app exited without becoming ready Starturn.hal:15: insmod for lincurve failed, returned -1 HALCMD ini file /home/operator/tmc/configs/tormach_lathe/Starturn.ini load failed with config file Starturn.hal Shutting down and cleaning up LinuxCNC...
Last edit: 7 years 3 months ago by davidimurray.
7 years 3 months ago #140323 by PCW
Replied by PCW on topic Lincurve and Pathpilot
I suspect (but do not know for sure) that you could simply copy lincurve.so
from a similar LinuxCNC installation (X86 64 bit LinuxCNC uspace )
One big change from PathPilot 1.x to 2.x is the change from a RTAI based RTOS
system to a Preempt-RT based RTOS
Real time library objects in RTAI are kernel modules (with a .ko suffix) but real time
library objects for Preempt-RT are userland modules (with a .so suffix)
  • davidimurray
  • Topic Author
  • Senior Member
  • Senior Member
7 years 3 months ago #140468 by davidimurray
Replied by davidimurray on topic Lincurve and Pathpilot
Thanks PCW
Would anyone happen to have a copy of the lincurve.so file they could share?
  • davidimurray
  • Topic Author
  • Senior Member
  • Senior Member
7 years 3 months ago #140471 by davidimurray
Downloaded a copy of lincurve.so from here fedora.pkgs.org/29/rpm-sphere-x86_64/lin...15.1.x86_64.rpm.html
Copied it over into pathpilot but still getting the same error.
7 years 3 months ago - 7 years 3 months ago #140473 by PCW
are the file permissions set as executable?
(make sure they match the permissions of the other .so files in the rtlib subdirectory)
Last edit: 7 years 3 months ago by PCW.
7 years 3 months ago #140475 by smgvbest
Replied by smgvbest on topic Lincurve and Pathpilot
I"ve got a copy build from the V2.0.5 source from tormach but my VM is refusing to connect to my network. soon as I can I'll put it in my dropbox and post a link
however, it's not saying it can't run it, it's saying it can't find it in your initial post
are you still getting that error.
7 years 3 months ago #140630 by smgvbest
finally got my PP network going again.
here's my dropbox link to the one on my PP install
www.dropbox.com/s/6b9i2e0wlyhu1wx/lincurve.so?dl=0
  • davidimurray
  • Topic Author
  • Senior Member
  • Senior Member
7 years 3 months ago #140685 by davidimurray
It works :)
I checked PCWs suggestion about ensuring properties were set to executable. After setting them I then got a new error about another missing library.
I then tried smgvbest version of lincurve with properties set to executable and it worked.
Need to do some more tests but hopefully that means I've now ported my parallel port lathe Linux setup over to Parallel port pathpilot lathe. A bit more testing required but once confirmed working I will share my setup to help others.
Thanks both of you for your help getting this working.
Dave
7 years 3 months ago #140693 by smgvbest
Cool , glad it worked for you
Time to create page: 0.072 seconds
