4th axis toolpath display
7 years 3 months ago #140856 by smgvbest
Replied by smgvbest on topic 4th axis toolpath display
"The None keyword is used to define a null value, or no value at all."
So because self is inferred by the call and widget is not used in the call at all, but since the call expects something None is passed.
so since self is inferred the call is effectively
self.enable_fourth_axis_toolpath_display()
7 years 3 months ago #140857 by Vmax549
Replied by Vmax549 on topic 4th axis toolpath display
OK that makes sense.
Question seeing how you run LinuxCNC does IT display teh 4th axis tool pathing correctly. Rotating teh toolpath and not teh tooltip icon .
Thanks, (;-) TP
7 years 3 months ago #140858 by smgvbest
If you're asking me, I don't run LinuxCNC, I do reference it for trying to find how things normally work but I run PP for a Lathe.
7 years 3 months ago - 7 years 3 months ago #140864 by pl7i92
Replied by pl7i92 on topic 4th axis toolpath display
you know that the Y and Z Join limit switch position in the INI file needs to change
so it is the mesurment between your Switch and the CENTER YZ of the Rotory table
the pathpilot does not display out of box g-code
i atatched the venusmilo file around A
Last edit: 7 years 3 months ago by pl7i92. Reason: file
7 years 3 months ago #140883 by Vmax549
I tried that file and it displays but does not run teh 4th axis toolpathing correctly. I have come to teh conclusion that PathPilot is not capable of a proper 4th axis toolpathing.
OH Well , It is what it is. (;-) TP
Time to create page: 0.324 seconds
