- Thank you received: 28
Test encoder signals
- Vmax549
- Topic Author
7 years 3 months ago #140494
by Vmax549
Test encoder signals was created by Vmax549
What is the best method to test the spindle encoder signals in PathPilot ??
TP
- pl7i92
- Thank you received: 358
7 years 3 months ago #140529
by pl7i92
Replied by pl7i92 on topic Test encoder signals
you can use halshow and set a counter to the signal so you see in watch tab if it is triggering the pulses
7 years 3 months ago #140548
He is using pathpilot, i never used it although i do have version 1.9 somewhere, it complained a lot when i did try to install it, so i abandoned it, for now.
Replied by tommylight on topic Test encoder signals
How ?pl7i92 wrote: you can use halshow and set a counter to the signal so you see in watch tab if it is triggering the pulses
- smgvbest
- Thank you received: 51
7 years 3 months ago #140552
by smgvbest
Replied by smgvbest on topic Test encoder signals
see my post here on enabling halshow in PPV2
forum.linuxcnc.org/pathpilot/35257-halsh...h-pathpilot-2#121725
if I can find I I'll post a patch to PP code to add a ADMIN HALSHOW command
Time to create page: 0.051 seconds
