PathPilot Startup Files???
  • billyjack
  • Topic Author
  • New Member
  • New Member
6 years 6 months ago #166084 by billyjack
PathPilot Startup Files??? was created by billyjack
This is a message I posted over on CNCZONE but will little success. I should have posted here first since this is by far the most active site for Linuxcnc.
Many thanks for any advice or guidance. If there is some online guidance I can't seem to find it.
Thx agn.
Hey folks;
Hopefully a simple question for those in the know. When PathPilot starts up which startup file does it look for meaning the Tormach_1100-3_specific.ini or the Tormach_1100-3.ini. I'm attempting to upgrade my Pro controls to PP 2.0 and looking at my history files I have a Tormach_1100-3.ini file that has been modified for the Torus Pro but the latest I have found has a file that I a Tormach_1100-3_specific.ini that points to a Novakon ini file that I just added with this upgrade. I don't think I need both the 1100-3 and the specific.ini files. Any ideas???
Bill
6 years 6 months ago #166095 by Clive S
Replied by Clive S on topic PathPilot Startup Files???
As I understand it. PathPilot uses the "specific ini" to pick the machine form from the list like 440 or any of the others then it uses the "base ini" to make the "Tormach_1100-3.ini" so if you need to edit the an ini file you have to edit the base ini then the system generates the Tormach_1100-3.ini.
If you open the Tormach_1100-3.ini you will see the message "this is machine generated"
6 years 5 months ago #166541 by Dorro1971
Replied by Dorro1971 on topic PathPilot Startup Files???
I think thats right..
Edit the base.ini file and the specific.ini file to make changes...at least thatls how i do it....i changed the specific ini file to load a different bitfile to my mesa board, and made config changes in the base.ini.....and HAL of course...
6 years 5 months ago - 6 years 5 months ago #166621 by smgvbest
Replied by smgvbest on topic PathPilot Startup Files???
if you go to the pp log in ~/gcode you can view exactly how its loaded.
base->specific->hal is basic sequence
i point this out to help learn how it works instead of just answering the question. understanding how pp works is key to making it work for anyones use case.
Last edit: 6 years 5 months ago by smgvbest.
  • billyjack
  • Topic Author
  • New Member
  • New Member
6 years 5 months ago #166622 by billyjack
Replied by billyjack on topic PathPilot Startup Files???
Thanks guys;
I got it figured out and am up and running version 2.1.2 but still no tool table. I'll post over in my other tool table specific thread. Thanks again.
Learning is a process and keeps the mind working.
Bill
Time to create page: 0.099 seconds
