PP 2.0 new computer install
- remartinez
- Topic Author
6 years 6 months ago #166096
by remartinez
PP 2.0 new computer install was created by remartinez
I would like to thank everyone in advance for helping out with this topic.
I am installing PP2.0 on a new computer GB-BXBT-1900 to run on an 1100M with an ECM1.4 board. After running the configuration picker I’m only able to pick PCNC1100. Unfortunately it will not start since the configuration is not correct as it looks for a Mesa card.
Is their a way to install the latest update of PP via terminal so that i can run the configuration picker and select the 1100M. This way it will run correctly without making any changes to PP files?
Once again thank you all!
Raul
Raul
6 years 5 months ago #166865
Replied by andypugh on topic PP 2.0 new computer install
Are you sure that any version of Pathpilot can run without a Mesa card?
It is possible that the ECM1.4 board _is_ a Mesa board, though. Watching a video on Youtube it looks to contain a Xylinx Spartan and is quite probably running the Hostmot2 firmware.
6 years 5 months ago #166899
by Dorro1971
Replied by Dorro1971 on topic PP 2.0 new computer install
..Could the ECM board be a rebranded Mesa?..like the Zbot tool changer board, i think
the hal file looks similar to the other mesa ones apart from more pins...
6 years 5 months ago #166902
No, I don't think that the ECM board is made by Mesa. The Mesa firmware is open-source, though, so anyone with an FPGA can run it.
I know at least two people who have made their own Mesa-like boards running the Mesa firmware and the normal LinuxCNC drivers.
6 years 5 months ago #166905
by Dorro1971
Thought of that myself too lol but for the price there's little point, one off multi layer pcb's are not so cheap...even from China..
I use the demo version of Xylinx for bitfiles but I haven't flashed from scratch yet...
Cheers.
Cheers.
6 years 5 months ago #167018
by Dorro1971
try holding down the left shift and alt at the tormach flash screen until you pc boots and the desktop appears.
when you get the desktop started, click on the green mint start button in the bottom left hand corner, go to home folder and click, find the file operator_login_running, duobke click it and select "run in terminal"
pick your machine and don't exit the error screen, now you can click on the terminal window and see what is the error...its probalbly a hal pin mismatch...
hope this helps.
hope this helps.
