Need help installing touch monitor on Pathpilot non Tormach Machine
6 years 3 weeks ago - 6 years 3 weeks ago #185793 by nor2020
I'm posting photos because the global menu is missing and I don't know how to get it back, or input my wifi password to access the internet.
If there is a situation with inputting passwords, I think we'll have an issue...I don't know the login password from the previous owner that I bought the machine from. I'm hoping there is no password.
Last edit: 6 years 3 weeks ago by nor2020.
  • BeagleBrainz
  • New Member
  • New Member
6 years 3 weeks ago - 6 years 3 weeks ago #185795 by BeagleBrainz
Can you try this:
lsmod
Did you edit the grub.cfg file ?
If not you maybe in luck.
Try this:
tormach.zendesk.com/hc/en-us/articles/36...athPilot-controller-
Last edit: 6 years 3 weeks ago by BeagleBrainz.
6 years 3 weeks ago #185796 by nor2020
No I did not edit a grub file.
6 years 3 weeks ago #185797 by nor2020
I tried the ADMIN TOUCHSCREEN command, it didn't work for me. Touch function still not working.
  • BeagleBrainz
  • New Member
  • New Member
6 years 3 weeks ago #185806 by BeagleBrainz
Unless you have the kernel sources and any patches that Tormach may have applied you won't be able to compile the kernel modules.
So unless anyone knows you may have to contact Tormach.
6 years 2 weeks ago #185852 by nor2020
Ok, I didn't realize it was going to be this complicated and require recompiling to get the touch function to work.
I thought it was going to be simpler as I read the PDF driver guide and it said to copy Xorg driver modules and edit a file. The PDF file did say that PS/2 interface would require kernel rebuild but not USB.
Time to create page: 0.106 seconds
