Encoder Index
5 years 11 months ago #190274 by Stigoe
Replied by Stigoe on topic Encoder Index
Clive S wrote: @stigoe
Longshot but is the encoder counting the correct way you might have to change the sign of the scale
Yep. The numbers increase when the spindle rotates in the normal direction (had to swap the wires earlier when the numbers decreased when the spindle was rotating the normal way).
But this gave me an idea to try. I checked the .ini-file and ENCODER_SCALE was set to 8000. I tried to set it to -8000 and ran the program. Now it was threading. Just checked the original .ini-file and it has a negative value as well. No idea why it needs to be negative when counting is increasing when the spindle is rotating the correct way. As long as it works, I'm fine with that... :)
Thanks for the help, everyone.
Br,
Stig
5 years 11 months ago #190277 by Clive S
Replied by Clive S on topic Encoder Index
Glad you got it working that's a common problem
5 years 10 months ago #193612 by jefsaro
Replied by jefsaro on topic Encoder Index
hello ,
i'am the same problem , and now , i put encoder -4096 , and it's ok ;
best wish
