- Thank you received: 28
Accessing the PathPilot ATC control
5 years 11 months ago #190780
by Vmax549
Accessing the PathPilot ATC control was created by Vmax549
Does anyone have an idea on how to fool PathPilot into thinking it has an ATC so that we can access the ATC pages ?? I have an ATC that runs from the M6 macro and would like to interface that into the PathPilot Page.
TP
5 years 9 months ago #195967
by smgvbest
Replied by smgvbest on topic Accessing the PathPilot ATC control
which PP Config did you use? was it one that supported the ATC aka PCN1100
Only a month late in responding. back problems
If its the PNC1100 you enable it in the Cong/Setup tab, just click ATC. its a model that does not support ATC then you have to manually enable all the code. they all use the same glade UI and py files so its all there. it just checks if the model supports it or not.
Time to create page: 0.036 seconds
