Start PathPilot without a Mesa card connected
24 Dec 2020 04:03 #193080 by atlantis
Hi
I don't have the Mesa card at hand yet, is there a way to trick PathPilot into starting up and not stopping with a missing Mesa card error? Sorry if this has already been discussed elsewhere and I just couldn't find it.
Regards
Martin
24 Dec 2020 08:33 #193114 by PCW
This might help, though it may not work with the latest PathPilot versions:
forum.linuxcnc.org/pathpilot/30222-setti...-port-tutoral-part-3
24 Dec 2020 09:09 #193120 by Vmax549
Replied by Vmax549 on topic Start PathPilot without a Mesa card connected
There is a DEMO setup for PathPilot if that is something you would consider.
(;-) TP
24 Dec 2020 18:08 - 24 Dec 2020 18:08 #193156 by snowgoer540
Replied by snowgoer540 on topic Start PathPilot without a Mesa card connected
Not to hijack, but I've always wondered how Pathpilot is able to start without power to the daughter card (their custom board)?
It doesn't complain about all of the pins not existing yet.
I'd love to make my plasma table do the same...
Last edit: 24 Dec 2020 18:08 by snowgoer540.
24 Dec 2020 19:08 #193159 by PCW
Tormach doesn't use any sserial devices (which are dynamically discovered
at startup) in their daughterboard, so can start LinuxCNC with it being powered.
Though I suspect they will not let the system out of EStop until all is powered
and working.
Why would you want to launch LinuxCNC when it cannot actually run?
24 Dec 2020 19:09 - 24 Dec 2020 19:11 #193160 by smgvbest
Replied by smgvbest on topic Start PathPilot without a Mesa card connected
you basically want to enter SIM mode which there are several ways to do it
1. in your .bashrc add
PATHPILOT_SIM_MODE=1, restart then start PP
2. run in a virtualized environment
3. in the MACHINE section of the ini file put in SIM=1
4. in the specific.ini file for your machine comment out the bit file.
all these force it into SIM mode which will not load the BIT file
Last edit: 24 Dec 2020 19:11 by smgvbest.
The following user(s) said Thank You: gerritv, Dorro1971
24 Dec 2020 20:19 #193163 by snowgoer540
and working.
You are correct, can’t do much until power is on and you “reset”.
Honestly, the biggest reason is that I forget to turn the cabinet on and LCNC yells at me :laugh:
Then I have to repeat the process of starting after I remember to turn on the cabinet. Otherwise, probably not much reason.
24 Dec 2020 20:40 #193164 by PCW
Its probably possible to launch LinuxCNC by deferring the parts of hal that access
the hardware to a hal section that's loaded later.
You could also have a script that determines if the hardware is available and puts
up a "Waiting for Control power" notifier until the hardware is detected
24 Dec 2020 22:54 #193168 by snowgoer540
I’m not sure how to execute that, but it would be awesome.
25 Dec 2020 10:27 - 25 Dec 2020 10:28 #193183 by PCW
Heres the basic idea:
#!/bin/bash
echo Waiting for control power
(exit 1)
while (($?))
do
  ping -c 1 -i .2 10.10.10.10 >/dev/null 2>&1
done
echo Starting LinuxCNC
linuxcnc
Someone with python or tcl smarts could do a nice graphic version
Last edit: 25 Dec 2020 10:28 by PCW.
Time to create page: 1.381 seconds
