Bit File for 7i76e
5 years 5 months ago #208837 by davidimurray
Hi All
Looking to start setting up my 7i76e with pathpilot. Does anyone know what would be the correct bit file to use to get the full I/O i.e mode 2?
Dave
5 years 5 months ago #208862 by PCW
Replied by PCW on topic Bit File for 7i76e
Standard firmware should be fine
SSerial modes are set in the hal file
5 years 5 months ago #208896 by davidimurray
Replied by davidimurray on topic Bit File for 7i76e
Thanks PCW.
Do you know which bit file is the standard firmware? I’ve downloaded the pack from the mesanet site but there are a few different versions for the 7i76 in there.
Dave
5 years 5 months ago #208937 by PCW
The standard firmware is pre-loaded in the 7I76E
the bitfile would be 7i76e_7i76x1d.bit
5 years 5 months ago #208959 by davidimurray
Thanks PCW - now to have a go at getting it working with PP.
I take it nobody has found a way to disable the bit file loading?
Cheers
Dave
5 years 4 months ago #211117 by yodaddy
Replied by yodaddy on topic Bit File for 7i76e
To avoid bitfile overwriting you need to edit your base or specific .ini file in ~/tmc/configs/tormach_mill and set "BITFILE0=mesa/7i76e_7i76x1D.bit", or whichever 7i76 bitfile you want to use.
Time to create page: 0.318 seconds
