Try doing it outside your config, using the simplest possible config.The board is set up as you described. I set hm2_7i76e.0.7i76.0.0.spinena TRUE, issued an M3 S5000 command, ran halcmd with "halcmd show all | grep hm2_7i76e.0.7i76 > dump", then checked the variables you listed and got output identical to what you listed.
