- Thank you received: 5
[apologies to the OP if this side conversation is going off-track]I think I’m picking up what you’re putting down.
I don’t follow the use case for case 1 since they are 3 different tools. But I do follow having the same tool with different features at different Z offsets.
Linuxcnc can do that.
T1 M6 G43 H1
T1 M6 G43 H2
T1 M6 G43 H3
Would be tool 1 at three different offsets. But if I understand it correctly, it’s still not exactly what you’d be after since H2 and H3 correspond to T2 and T3’s offsets.
Unless I’m completely misinterpreting it. Admittedly I didn’t spend a ton of time on researching it …
A case comes to mind where the OP is doing prototype work and using a lot of tools NOT in the tool changer. Instead of unloading the ATC and reloading with the correct tools the OP simply manually changes tools and assigns the tool length offsets by changing the H#. The tool number stays the same and just the H# changes. This can save a ton of time when working on an unknwn prototype.
SO IF you knew the last H# and stored it away in a #param when it comes time to restart with the tool changer simply put back in the last Tool the ATC ran and input the saved H# and you are back in business. I know simply write it down ?? Yes but that is me working for the machine I prefere it the other way around (
(TP
Me, too. The only mill-use case I can imagine on short notice is a combination tap-drill. One of those things that has about an inch of drill flutes followed by 1/2" or so of tap threads.I do still struggle to see the application in a mill, more specifically a Tormach one.
