- Thank you received: 4
Need basic ini/hal/pathpilot.json files for new versions 2.10/2.12
- gmouer
- Topic Author
1 year 8 months ago - 1 year 8 months ago #321606
by gmouer
Need basic ini/hal/pathpilot.json files for new versions 2.10/2.12 was created by gmouer
Been trying to get PP 2.12 to boot in a bare bones configuration to get me started on a non-tormach retrofit. All the instructions and sample files here on the forum will not work with the latest versions, I tried them all.
What I am looking for is hal/ini and pathpilot files (bare bones) just to get me booted and started. Eventually I will be using a 5i25/7i77 mesa but do not want to take them from a working machine until I get much closer to a working pathpilot configuration.
Can anyone help me out with some sample files, something similar to the ones in the tutors here but more current that will work with 2.12 pathpilot. (2.10 would be ok too to get me started)
Thanks !
Thanks !
Last edit: 1 year 8 months ago by gmouer.
- phomann
- Thank you received: 10
1 year 7 months ago #325098
by phomann
Replied by phomann on topic Need basic ini/hal/pathpilot.json files for new versions 2.10/2.12
did you look through this thread where I got PathPilot running on a non-Tormach mill?
forum.linuxcnc.org/pathpilot/45846-pathpilot-7i92-g540-hal-file
cheers,
Peter.
cheers,
Peter.
The following user(s) said Thank You: gmouer
- gmouer
- Topic Author
1 year 7 months ago #325248
by gmouer
Replied by gmouer on topic Need basic ini/hal/pathpilot.json files for new versions 2.10/2.12
I sure did look at your thread and files.
What I am basically looking for is a minimal hal file that will allow PP to start. I don't know which parts of the various hal files posted are mandatory and needed to get PP to launch, leaving out anything not mandatory.
In the end I will use it on a bridgeport that has servo's using a 5i25 and 7i77 board. The mill has been operational for years using linuxcnc but I would like to switch to PP mostly for the excellent conversational. I have not seen any other conversational that even comes close. (I have used nativecam which is the next best thing)
Meanwhile, I have made progress. I got it to launch in sim mode. I also got a INI file that works with the mesa cards I have but crashes due the hal file various pins etc being wrong.
A absolute minimal hal file would help lots, I can add to that once I have PP launching withuot crashes.
- gmouer
- Topic Author
1 year 6 months ago #327042
by gmouer
Well it seems that pathpilot under non-tormach machines is all but ancient history. I can understand why. PP is so over complicated that it is extremely difficult to decode the software and modify it. I got it somewhat adapted to my bridgeport but not completed.
Meanwhile...... NativeCam has now been adapted to the newest versions of linuxcnc and I have that working. The main desirable feature of PP was its conversational BUT NativeCAM is actually far superior.
I used NativeCam for years but couldn't update linuxcnc because NativeCam wasn't compatible after LCNC went to Python3. All that is fixed now.
Time to create page: 0.053 seconds
