- Hardware & Machines
- CNC Machines
- Plasma & Laser
- activate output pin 7i76e via m62 65 for use with Plasmac extra buttons
- CNCFred
- Thank you received: 43
18 Mar 2020 03:59 #160636
by CNCFred
activate output pin 7i76e via m62 65 for use with Plasmac extra buttons was created by CNCFred
my machine in PLASMAC is called plasmathc
if I create a laser.hal file add it to plasmathc.ini
can I enable a output pin using m62 m65 code with a button from the ten user buttons in the Plasmac Extras panel?
the laser.hal file would be:
net laser motion.digital-out-00 =>hm2_7i76e.0.7i76.0.0.output-06
further I have crane control panel connected. estop works but it has two buttons up and down they are hooked up to hm2_7i76e.0.7i76.0.0.input-06 and hm2_7i76e.0.7i76.0.0.output-05
I would like to use them as pause and resume , or to increase cutting velocity or decrease during operation. I am using version 2.9!
could you kindly lead me in a direction ....
thank you...
thank you...
- phillc54
- Thank you received: 2100
18 Mar 2020 05:45 #160638
by phillc54
Replied by phillc54 on topic activate output pin 7i76e via m62 65 for use with Plasmac extra buttons
I think that would work. You would only use M64 and M65 as there is no motion while using the laser.
Another option would to use M7 (mist coolant on) and M9 (all coolant off) and connect like:
For pause and resume you could connect to :
halui.program.pause and halui.program.resume
linuxcnc.org/docs/html/man/man1/halui.1.html
net laser iocontrol.0.coolant−mist => hm2_7i76e.0.7i76.0.0.output-06For pause and resume you could connect to :
The following user(s) said Thank You: CNCFred
- CNCFred
18 Mar 2020 07:53 #160644
by CNCFred
Replied by CNCFred on topic activate output pin 7i76e via m62 65 for use with Plasmac extra buttons
thank you again...
I found that coolant-mist is already hooked up? in my plasmathc it seems.
plasmathc.hal:net coolant-mist <= iocontrol.0.coolant-mist
did I understand this means a hal pin is hooked up to a signal name? but no physical pin ...
linuxcnc is hard tobacco for me.
- Thank you received: 1482
18 Mar 2020 10:48 #160647
Replied by Todd Zuercher on topic activate output pin 7i76e via m62 65 for use with Plasmac extra buttons
Yes that line,is creating the signal "coolant mist" and connecting it to the hal pin "iocontrol.0.coolant-mist"
To connect them to your output add another line some where in a hal file.or simply append " => hm2_7i76e.0.7i76.0.0.output-06" to the end of the previous line of hal code.
net coolant-mist <= iocontrol.0.coolant-mistTo connect them to your output add another line some where in a hal file.
net coolant-mist => hm2_7i76e.0.7i76.0.0.output-06
- CNCFred
18 Mar 2020 13:19 #160668
by CNCFred
slowly I get a very small part of it..
thank you!!
thank you!!
- CNCFred
18 Mar 2020 15:02 #160673
by CNCFred
- phillc54
18 Mar 2020 17:15 #160682
by phillc54
Glad you got it going.
- thefabricator03
- Visitor
18 Mar 2020 22:36 - 18 Mar 2020 22:36 #160704
by thefabricator03
Replied by thefabricator03 on topic activate output pin 7i76e via m62 65 for use with Plasmac extra buttons
That is pretty cool that we can do such things with the software. I really enjoy seeing things like this being implemented and the real world benefits that it has. Sometimes simple changes can make a big difference to how well something works day to day.
Last edit: 18 Mar 2020 22:36 by thefabricator03.
- CNCFred
19 Mar 2020 02:02 #160714
by CNCFred
at the end the change is simple, on the beginning it is difficult & to get there is a lot of reading and (not) understanding ...and is still far away from using AND OR
The code to move the torch where the laser cross midpoint is
G10 L20 P1 X0 Y0 Z0\G0 X##### Y#####\G10 L20 P1 X0 Y0
#### are the values manually measured
G10 L20 P1 X0 Y0 Z0 deletes the coordinates (not quite sure g54?)
- phillc54
19 Mar 2020 02:06 #160715
by phillc54
If you use P0 rather than P1 it will use the Work Coordinate System that is current.
So if you are currently in G54 it will use G54.
- CNC Machines
- Plasma & Laser
Time to create page: 0.715 seconds
