Encoder improvements for THCAD
23 May 2020 03:04 - 23 May 2020 03:56 #168640 by PCW
Encoder improvements for THCAD was created by PCW
LinuxCNC master has a minor change in the encoder driver code to improve frequency
measurement resolution, This will improve the noise performance of the THCAD
somewhat so is worthwhile enabling. What changed was the timestamp frequency
that is used for encoder velocity/frequency calculations. This was set to nominally
1 MHz before the change. This default frequency has been increased to 2 MHz and
now has an option allowing a 10 MHz frequency to be selected. To select a 10 MHz
timestamp frequency, you set the hm2_card.0.encoder.hires-timestamp pin "true"
Last edit: 23 May 2020 03:56 by PCW.
The following user(s) said Thank You: chimeno, tommylight, rodw, dvn4life1972
23 May 2020 03:16 #168643 by rodw
Replied by rodw on topic Encoder improvements for THCAD
Thansk Peter. So users of master branch chould enable the 10 Mhz setting for best performance? I take it this specific to mesa hardware and the hostmod2 driver?
Sounds like this will be useful fo those cheaper plasma cutteres wher ethe arc voltage signal is quite noisy.
23 May 2020 03:58 #168647 by PCW
Replied by PCW on topic Encoder improvements for THCAD
Yes, this is HostMot2 specific, and actually the difference will be most apparent
where the signal is cleanest.
The following user(s) said Thank You: Clive S, rodw
23 May 2020 08:53 #168664 by tommylight
Replied by tommylight on topic Encoder improvements for THCAD
Nice timing, as i might get finally today or tomorrow my 4 THCAD's ! :)
24 Jun 2020 18:21 #172606 by snowgoer540
Replied by snowgoer540 on topic Encoder improvements for THCAD
So to enable this, all I have to do is change hm2_card.0.encoder.hires-timestamp to true?
24 Jun 2020 18:51 #172613 by tommylight
Yup, that is it.
Have not tested it yet, so will do that promptly ... just as soon as i finish adjusting some drag chains on both machines. :)
24 Jun 2020 19:23 #172617 by tommylight
Enabled it and now there is no encoder velocity ? Instead of velocity and voltage i get "inf" .
24 Jun 2020 20:11 #172626 by PCW
What hardware and servo thread rate do you have?
24 Jun 2020 20:12 #172627 by tommylight
Mesa 7i92, servo at 1ms.
24 Jun 2020 20:31 #172631 by PCW
Hmm I can't duplicate this with a 7I92 and a 1 ms servo thread (or 7i96 or 7I76E)
Time to create page: 0.178 seconds
