ArcOK when not built-in
5 years 5 months ago #210062 by samforsey12345
You might find that the plasma cutter has a neat one internally. Picture shows tight coil of copper with a reed switch glued in on the ground side. Ideal really...
I didn't end up using it but expect would be highly reliable
5 years 5 months ago #210067 by Clive S
Replied by Clive S on topic ArcOK when not built-in
phillc54 wrote: I am pretty sure they the type that Clive used here:
linuxcnc.org/docs/devel/html/plasma/qtpl....html#qt_reed-arc-ok
Yes to confirm I used a glass one from an alarm contact fitted inside a bit of plastic tube with about 3 turns of the ground clamp cable as shown in the pic
5 years 5 months ago #210091 by Joco
Replied by Joco on topic ArcOK when not built-in
Clive - so did you just use the alarm part as is or did you extract the reed switch from it?
I have a couple of bare glass reed switches that i will need to mount on some perf board to be useable. Easy to do and easy to add some screw terminals. But perhaps not as clean as just using pre built reed side of an alarm switch with screw terminals all ready to go.
Cheers.
5 years 5 months ago #210100 by tommylight
Replied by tommylight on topic ArcOK when not built-in
-solder two wires to reed
-get a pen and cut a length a bit longer than reed body
-insert reed in
-wind 3 turns of the ground or the torch lead
-use zip ties to secure the windings in place.
The worst thing in all of that is the wire, it is thick and hard to wind, most times to short so lengthening is needed. Takes about 15 to 30 minutes of time.
2 years 9 months ago #291636 by vre
Replied by vre on topic ArcOK when not built-in
What reed switch is suitable? any link?
2 years 9 months ago #291646 by tommylight
So far any reed i used just worked, be it the glass ones or plastic ones. Usually 20-25mm in length, no idea what model or type.
Time to create page: 0.187 seconds
