Laser Advice and Guidance - Mesa Card
5 years 4 months ago #213371 by chris@cnc
If the laser module input is TTL compatible; it should be OK
as long as there is a common ground (laser GND goes to 7I76E Gnd)
If you are concerned, you could add a say 220 Ohm resistor in series with the PWM output
Thank you for information,Yes laser is TTL compatible. I take now a second lesson "howto measure with scope" and found hopefully the right pins.
Just for double check. I only have this 4 Pins on laser input card.
I would now connect Laser as follow
+24V --> powersupply same for mesa card
GND --> powersupply same for mesa card
TTL + --> + 220 Ohm resistor -->TB3 PIN3
TTL-  --> TB3 PIN 1
I haven't found any recent implementations.  Would it be possible for you to share your *ini and *.hal files when you get it up and working?
Yes i also haven't found anything. But i like the idea to control laserpower by z high.
If its running i will share my config but for the moment i test only with this 4 lines.
I order the laser yesterday. Maybe delivered next month. I need more time to get it running.
But for today it looks not so bad. I set "halcmd setp hm2_7i76e.0.pwmgen.00.scale 5"
And PWM power now by Z-1.000 1.2V and Z-4.000 4.7V and Z-5.000 5V. So we could adjust laserpower depend on material.
5 years 4 months ago #213372 by chris@cnc
And what ist PDM frequency? I change it but nothing happens on scope...
5 years 4 months ago #213407 by PCW
It only affects PDM mode (output-type 3)
5 years 3 months ago - 5 years 3 months ago #213717 by vre
something new about mesa datapainter and galvo interface firmware for raster greyscale engraving ?
Last edit: 5 years 3 months ago by vre.
5 years 3 months ago - 5 years 3 months ago #216135 by chris@cnc
It works now. Important lines.
Hal changes
# -----------PWM Generator signals/setup--- setp   hm2_7i76e.0.pwmgen.pwm_frequency 20000 setp   hm2_7i76e.0.pwmgen.00.output-type 1 setp   hm2_7i76e.0.pwmgen.00.scale  4 #------------ Laser relay main switch------------------------ net w-enable => hm2_7i76e.0.7i76.0.0.output-15  # -------------laser pwm enable by program cycle start, off by program stop, pause.... net halui.program.is-running   => hm2_7i76e.0.pwmgen.00.enable                 net w-enable    <= joint.6.amp-enable-out         net w-pos-cmd   <= joint.6.motor-pos-cmd net w-pos-cmd   => joint.6.motor-pos-fb     hm2_7i76e.0.pwmgen.00.value
INI changes
[KINS] JOINTS = 7 KINEMATICS = trivkins coordinates=XYYZZAW kinstype=BOTH [TRAJ] COORDINATES =  XYYZZAW #************  Laser dummy axis  ****************************** [AXIS_W] MAX_VELOCITY = 1000.0 MAX_ACCELERATION = 1000.0 MIN_LIMIT = -4 MAX_LIMIT = 0.5 [JOINT_6] TYPE = LINEAR HOME = 0.0 FERROR = 10.0 MIN_FERROR = 1.0 MAX_VELOCITY = 1000.0 MAX_ACCELERATION = 1000.0 MIN_LIMIT = -4.0 MAX_LIMIT = 0.5 HOME_OFFSET = 0.0 HOME_SEQUENCE = 5
Last edit: 5 years 3 months ago by chris@cnc.
5 years 3 months ago #216395 by Doogie
FWIW, M67 is not a buffer buster and I have it working on my K40 laser via LinuxCNC/Remora but I would think it could be configured similarly for Mesa.  Thread on this is here:  forum.linuxcnc.org/49-basic-configuratio...ting?start=30#212849
Time to create page: 0.432 seconds
