Please help with adding laser control
1 year 3 months ago #331397 by SjCNC
Long story short, I need help getting laser control working again.
Setup was functional with the main diode laser (which failed one day), then edited to use a cheaper diode laser.  I tried switching everything back over after repairing the main laser, and it's been a downward spiral.
I'm now pot committed to starting from scratch.  Setup is a 7i76e, with a 5 axis BoB on expansion port P1.  OS has been upgraded to 2.9.4, and 7i76e_7i76x1_5abobpD.bit has been flashed to the board.
The attached config is just a basic pncConf output.  Any guidance for implementing PWM would be greatly appreciated.
1 year 3 months ago #331410 by Benb
I think it would be helpfull to mention your previous os version and linuxcnc version, also include hal and ini pre-overhaul when the machine was operating properly.
1 year 3 months ago #331412 by SjCNC
Agreed, this has had me stall posting for a few weeks...Pretty sure I was using 2.7.14 when setting up the 7i76e, and 2.8.2 most recently.I've not been great with version control, while moving across computers and machines. These might be the last working files, but unsure...  Laser signal as 'sj' in line 39
1 year 3 months ago #331417 by Benb
My suggestion is to use:
www.diffchecker.com/
I tested by cutting/pasting your previous and new files; it shows the difference and it gives you the ability to merge the differences line by line.
1 year 3 months ago #331418 by PCW
If you don't want to use your old config, you could simply copy all the
lines from the old hal file that contain 'pwm' and import them into your
new hal file.
1 year 3 months ago #331423 by SjCNC
I've got to get better at asking the right questions... Using the old config:
signal 'sj'
motion.analog-out-00, and
hm2_7i76e.0.pwmgen.00.value
All these values update as M67 changes the output.
hm2_7i76e.0.gpio.017.in toggles to True when the gcode starts running.
Does everything seem mapped right for the PWM to reach pin 1 on a 5 axis breakout board? Should that be on hm2_7i76e.0.gpio.017.in? Maybe the code is fine, and I should be chasing down a hardware issue?
Time to create page: 0.082 seconds
