Thanks for checking things over PCW!
I can't setp the value since it's linked to a signal, but when gcode runs M67 E0 Q0, GPIO 017 does go false.
'setp hm2_7i76e.0.pwmgen.00.scale 100' has been added, this may yield better results. Since I didn't set the scale, all values (1-100) were sending full power. This tip right here may be the biggest sanity check, thanks PCW!
