Stahlwerk Plasma Cutters THC Interface
  • Nilres
  • Topic Author
  • New Member
  • New Member
1 year 1 week ago #336936 by Nilres
Hi,I'm currently on my journey to build a CNC Plasma Cutter. For the plasma source I'm looking into the Stahlwerk Line-Up of Plasma Cutters (Cut70 or Cut100). All Stahlwerk Cutters have a build in THC Connector. What I can't figure out is if this connector is already divided. Or if an external divider circuit is needed. The Manual just says that it is used to connect the cutter to a CNC controller. Does anyone have detailed information? Or own such a device at has already checked the voltage levels? Greetings
Nils
1 year 1 week ago #336939 by Hakan
Replied by Hakan on topic Stahlwerk Plasma Cutters THC Interface
If it's this one www.stahlwerk-schweissgeraete.de/plasmas...t70-pilotzuendung-en
I would look at one that doesn't use HF start. You don't want HF start in cnc table.
Generally, blowback start is what you want.
1 year 1 week ago #336950 by rodw
Replied by rodw on topic Stahlwerk Plasma Cutters THC Interface
The THC voltage is raw cutting voltage. a THCAD can use this with the right scaling resistors. I would expect there are some resistors between these terminals and the cutting terminals to avoid lethal current! Check with a multimeter.
here the thcad manual is your friend. 200 V full scale will be best but 300v is also Ok
1 year 1 week ago #336958 by tommylight
Replied by tommylight on topic Stahlwerk Plasma Cutters THC Interface
Black ones, maybe, the white ones not all for sure.
They are good and have a few years warranty, but aim for 70A at least, the exact one that Hakan proposed.
1 year 1 week ago #336961 by Hakan
Are you sure, Tommy? It got HF start.
1 year 1 week ago #336964 by tommylight
Yes i am, i have 3 or 4 of those in daily use, 1 with Proma THC150 and others with Mesa THCAD.
I also have a china one with same electronics and pilot arc, the HF type, i intentionally wired the THCAD10 to the main terminals with 1MOhm resistors on each side, still in daily use for nearly a year, no issues.
The thing is, with correct wiring and grounding and shielding, it works fine, but any wiring error will result in burnt electronics the first time the torch fires, hence i refrain from advising such things.
The following user(s) said Thank You: Hakan
  • Nilres
  • Topic Author
  • New Member
  • New Member
1 year 1 week ago #337046 by Nilres
Replied by Nilres on topic Stahlwerk Plasma Cutters THC Interface
Thanks for the support.
I think my initial question is answered. I will look how I safly devide the voltage to get it into my control logic.
The information about HF start vs. Blowbackstart are also helpful. I know that the Stahlwerk machines are not "perfect" but I hope they offer a fairly good compromise for the price.
Greetings
Nils
1 year 1 week ago #337057 by tommylight
Pretty sure they have 7 years of warranty, and for me that is more than enough.
