Looking for opinions on controller box
1 month 3 weeks ago #349505 by Burrow_87
This is my first time building something like this cnc plasma table so looking for opinions on what I can improve before wiring everything.
7I96S
THCAD2
24v 16Amp psu
5v 4 amp psu
dm556 drivers (x, y1, y2, z, a)
5v relays for arc and torch control
8 opto isolators for limit switches (2 x, 2 y1, 2 y2, z, z touch)
e stop
If you room for improvement please chime in and let me know before I attempt to not make a rats nest of wires.
1 month 3 weeks ago #349512 by arcsynapse89
Looks like its going to be a tidy control box. If it were my build I would put the 7I96S closer to the drives to shorten all the drive wiring, keep the THCAD2 and relays close to the 7I96S for the same reason.
1 month 3 weeks ago #349514 by Burrow_87
Unfortunately I have to keep the card and power on that side so I can get to Ethernet, on/off switch and estop. The way the table is set up I can only get to that side of the control box when in use.
1 month 3 weeks ago - 1 month 3 weeks ago #349516 by arcsynapse89
 On one of my builds I used a pass through ethernet port mounted on the panel to use a small ethernet cable to connect to my 7i76e. Its hard when you have limited access but I overcame the problem with a short ethernet cable inside the box.
Last edit: 1 month 3 weeks ago by arcsynapse89.
1 month 3 weeks ago #349517 by tommylight
Get rid of the relay boards, opto boards and the 5V rails, you do not need them and they will only add to stuff collecting interference, Mesa 7i96S has isolated inputs and outputs, just check what output to connect the torch on as there should be two types of outputs on it.
Put the Mesa board in the middle vertically with LAN side down, THCAD and power supplies to the right and drives as they are.
1 month 3 weeks ago #349523 by rodw
I agree with Tommy. Pointless adding additional failure points!
I would try and arrange the drives horizontallly as there is a risk the top drives overheat with the heat from the ones below. I have had this happen but at a lot more than 24 volts (which I think is too low, velocity and acceleration are king with plasma and you are limiting yours by the low voltage)
Time to create page: 0.197 seconds
