Latest Update lost THC
4 years 3 months ago #248072 by wade956
Hi, it appears something has changed with my THC. When I used my machine today it lost voltage scale and offset information. I put those back in but I’m not getting any float height or cut height any more (torch drags on the sheet)
I also can’t seem to get run from line to work any more either. Has that changed?
thanks again for the help.
4 years 3 months ago #248077 by snowgoer540
Replied by snowgoer540 on topic Latest Update lost THC
Can you post a backup of your config from the settings tab?
4 years 3 months ago #248080 by wade956
Replied by wade956 on topic Latest Update lost THC
See attached
File Name: qtplasmac_...07-22.gz
File Size:14.2 KB
4 years 3 months ago #248081 by snowgoer540
It’ll probably be a bit until I am in a position to take a look. Phill will probably beat me to it, but the backup really helps.
Also in the meantime, is this something you cut regularly or a new cut file? If it’s a new cut file and you can post that too, it may help.
4 years 3 months ago #248082 by wade956
It’s old files. Also I tried just a square on the conversational and it did the same thing. It’s sees the float switch come on but doesn’t seem to do much other than stop z axis.
4 years 3 months ago #248083 by wade956
Looks like run from line was disabled. This is fixed now
Time to create page: 0.216 seconds
