Laser Button Doesn't toggle to mark edge and origin
1 year 1 week ago - 1 year 1 week ago #337063 by wels
I am Trying to set up a laser to align the work to the sheet in QTPlasmaC, however, it does not appear to be working properly. In the owners manual it says it should change to mark edge and then mark origin. it just changes to show it is turned on. What am I missing?
Last edit: 1 year 1 week ago by wels. Reason: missed info
1 year 1 week ago #337066 by wels
I forgot to mention that this is in QTPlasmaC
1 year 1 week ago #337067 by snowgoer540
Did you make a custom user button for your Laser, or are you using the LASER button in the DRO box?
1 year 1 week ago #337068 by wels
Is the DRO box the buttons added in settings, then yes. I just found that I need hal pin
qtplasmac.ext_laser_touchoff
I have to figure out where to put it and if it will work...
1 year 1 week ago #337069 by snowgoer540
I am going to assume you made a custom button for your laser.  The LASER button in the DRO box is not shown until a offset is set, I reckon the user manual does not explicitly say that.  I'll mark it down to add it to the docs later.
Assuming you made the correct HAL connections
You need to use the peripheral offsets section to set the offset between the torch and the laser, and then the LASER button will appear.
The following user(s) said Thank You: wels
1 year 1 week ago #337071 by snowgoer540
That is not quite right. You just need to finish the following hal connection in either the <machine_name>.hal file or the <machine_name>_connections.hal file, I cant remember where it is off the top of my head.
# --- PLASMAC:LASER-ON --- net plasmac:laser-on => YOUR_OUTPUT_PIN
Then do the peripheral offsets part and the LASER button will show.
Time to create page: 0.260 seconds
