FreeCAD Gcode not working in Linuxcnc
- strahlensauger
- Thank you received: 66
22 Jan 2022 22:24 #232838
by strahlensauger
FreeCAD Gcode not working in Linuxcnc was created by strahlensauger
I constructed a gnome door for the kids in FreeCAD and as I put it on my mill, Linuxcnc only showed huge circles instead of the door.
I inspected the gcode and found large I and J Parameters, which LCNC probably interprets wrong. If I delete code from line 150 onward and keep the last thee lines the code behaves as expected.
This occurs on my real machine as also on simulation.
Any ideas?
Any ideas?
- Thank you received: 2181
23 Jan 2022 09:24 #232868
Replied by cmorley on topic FreeCAD Gcode not working in Linuxcnc
I don't see G64 setting - that can make corners _very_ rounded.
- strahlensauger
23 Jan 2022 14:30 #232877
by strahlensauger
Replied by strahlensauger on topic FreeCAD Gcode not working in Linuxcnc
Thank you for answering, I'll check that.
Opening the code in ncviewer.com/ shows the correct lines,
just Linuxcnc shows great circles.
This happens on a test RPI running LCNC as well as on my mill as well as on a simulation under Linuxcnc.
I wonder if I am the only one experiencing such strange behaviour, the drawing just consists of straight lines...
Changing Gcode G90 to G91 shows me at least the drawing inbetween huge circles in LCNC.
If I move the corner points in FreeCAD sometimes the circles disappear (probably when the i and j Parameters get small) but I can not detect any systematical sheme in that...
- Grotius
- Thank you received: 2349
23 Jan 2022 23:33 #232907
by Grotius
Replied by Grotius on topic FreeCAD Gcode not working in Linuxcnc
At my place the gcode looks like :
user-images.githubusercontent.com/448801...3f0-4f5c9bea11d2.mp4
Is this looking ok for you?
- phillc54
- Thank you received: 2100
24 Jan 2022 00:41 #232908
by phillc54
Replied by phillc54 on topic FreeCAD Gcode not working in Linuxcnc
- joekline9
- Thank you received: 9
24 Jan 2022 00:48 #232910
by joekline9
Replied by joekline9 on topic FreeCAD Gcode not working in Linuxcnc
It may be the wrong arc center mode.
G90.1 ( abs arc centers)
or
G91.1 ( incremental arc centers)
or
- strahlensauger
24 Jan 2022 01:09 - 24 Jan 2022 01:27 #232912
by strahlensauger
Thank you for your engagement. That is exactly what I drew in Freecad, lcnc draws huge circles.
I just wonder why the postprocessor from freecad for Lcnc don't match.
Last edit: 24 Jan 2022 01:27 by strahlensauger.
- phillc54
24 Jan 2022 01:15 #232915
by phillc54
Yes, It does seem that LinuxCNC is interpreting it incorrectly.
If you zoom in a long way where the circles intersect on the left side then you can see the rest of the plot.
It may be best to raise a new issue on Github.
github.com/LinuxCNC/linuxcnc/issues
The following user(s) said Thank You: strahlensauger
- strahlensauger
24 Jan 2022 15:12 #232973
by strahlensauger
I opened an issue on Github, thank you for the link.
@ phillc54: just curious; how did you edit that file to change the lines with the big numbers,
did you do all by hand or did you write a macro in vim or did you use Excel or libreoffice?
- phillc54
24 Jan 2022 22:23 #233020
by phillc54
By hand, it is easy to find the required line by selecting it in the preview.
Time to create page: 0.320 seconds
