Hey Guys,
Just got this installed and on attempt to open I am getting this:
File "/home/tc225/.local/bin/qtpyvcp", line 11, in <module>
load_entry_point('qtpyvcp==0.2.3+208.g82c29ba', 'console_scripts', 'qtpyvcp')()
File "/home/tc225/.local/lib/python2.7/site-packages/qtpyvcp/__init__.py", line 91, in main
run_vcp(opts, None)
File "/home/tc225/.local/lib/python2.7/site-packages/qtpyvcp/__init__.py", line 114, in run_vcp
load_vcp(opts)
File "/home/tc225/.local/lib/python2.7/site-packages/qtpyvcp/vcp_launcher.py", line 130, in load_vcp
_load_vcp_from_entry_point(vcp, opts)
File "/home/tc225/.local/lib/python2.7/site-packages/qtpyvcp/vcp_launcher.py", line 179, in _load_vcp_from_entry_point
vcp.main(opts)
File "/home/tc225/.local/lib/python2.7/site-packages/examples/probe_basic/__init__.py", line 19, in main
qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)
File "/home/tc225/.local/lib/python2.7/site-packages/qtpyvcp/__init__.py", line 141, in run_vcp
launch_application(opts, config)
File "/home/tc225/.local/lib/python2.7/site-packages/qtpyvcp/vcp_launcher.py", line 77, in launch_application
loadWindows(config)
File "/home/tc225/.local/lib/python2.7/site-packages/qtpyvcp/vcp_launcher.py", line 208, in loadWindows
window = _initialize_object_from_dict(window_dict)
File "/home/tc225/.local/lib/python2.7/site-packages/qtpyvcp/vcp_launcher.py", line 202, in _initialize_object_from_dict
return obj(*args, **kwargs)
File "/home/tc225/.local/lib/python2.7/site-packages/examples/probe_basic/probe_basic.py", line 18, in __init__
super(ProbeBasic, self).__init__(*args, **kwargs)
File "/home/tc225/.local/lib/python2.7/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 44, in __init__
self.loadUi(ui_file)
File "/home/tc225/.local/lib/python2.7/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 103, in loadUi
uic.loadUi(ui_file, self)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/__init__.py", line 226, in loadUi
return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/Loader/loader.py", line 72, in loadUi
return self.parse(filename, resource_suffix, basedir)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 1000, in parse
actor(elem)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 807, in createUserInterface
self.traverseWidgetTree(elem)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 785, in traverseWidgetTree
handler(self, child)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 262, in createWidget
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 482, in createLayout
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 525, in handleItem
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 253, in createWidget
self.stack.push(self.setupObject(widget_class, parent, elem))
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 217, in setupObject
obj = self.factory.createQObject(clsname, name, args, is_attribute)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/objcreator.py", line 106, in createQObject
factory = self.findQObjectType(classname)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/objcreator.py", line 131, in findQObjectType
w = module.search(classname)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 115, in search
module = __import__(mname, {}, {}, (cls,))
File "/home/tc225/.local/lib/python2.7/site-packages/qtpyvcp/widgets/display_widgets/atc_widget/atc.py", line 14, in <module>
from qtpy.QtQuickWidgets import QQuickWidget
File "/home/tc225/.local/lib/python2.7/site-packages/qtpy/QtQuickWidgets.py", line 14, in <module>
from PyQt5.QtQuickWidgets import *
ImportError: No module named QtQuickWidgets
