[Error] - Requested Tool Not Found
6 years 2 months ago - 6 years 2 months ago #179710 by TurBoss
@Gast456
> Not really sure what you mean with that? What is a master version and how can I find out that I use one?
it can be found in github
github.com/kcjengr/qtpyvcp/
github.com/kcjengr/qtpyvcp/releases
that is the version on we put the new features and test
it has the latest features but not stable like releases
www.qtpyvcp.com/install/index.html
check the standard install it only will install the runtime environment( releases )
and developer install will give you all the development tools
Thanks for your interest
Last edit: 6 years 2 months ago by TurBoss.
6 years 1 month ago #181918 by Nabazul
I am getting the exact same error and cannot figure it out. Whenever i add a tool to my list (probe basic gui) the pocket is set to -1. Changing it always sets it back to -1. Running an T1 M6 command always puts out an Tool does not exist error (even though T1 it is in the list). What is even funnier: When i press the "touch off current Tool" button it is touching off the tool, posting the distance and then deletes all entries in the tool table (overwriting the file as well). And the touch off macro does not finish (after deleting the tools). Im am running stable 0.3.8 release.
Any idea what the problem might be? One thing i noticed is that my ATC Tab does not work. I kind of ignored since i am not planning to use it anyway since i have to manually change my tools. Could it be that this is related to my problem?
6 years 1 month ago #181924 by tommylight
Had the issue of tool number -1 some days ago and the only way i could change it was to edit the hal file and connect tool_requested to tool_changed, start LinuxCNC and do a tool change, then edit back the hal file. It was on a machine with 8 pocket tool changer.
6 years 1 month ago #182015 by Nabazul
so i did some more messing around. When i copy over the too table from the sim everything including touching off tools works. However as soon as i hit "save tool table" all the pockets are set to -1 and eventually the tool database gets cleared and overwritten again. I have no idea what is going on. Could this be a problem with metric vs imperial?? My machine is set in mm and the imported tool database is in inch.
6 years 1 month ago - 6 years 1 month ago #182021 by TurBoss
hello, this looks like a bug
edit:
this looks like the problem
can you upload the sim tooltable
thanks
Last edit: 6 years 1 month ago by TurBoss. Reason: add details
6 years 1 month ago #182025 by tommylight
The tool number -1 has norhing to do with QtPyVCP or metric/imperial, it is most probably caused by power off of the PC and the resulting corruption in the files. That was my case.
Loop the tool change, change a tool, then revert back, that fixed it for me.
Moderators: KCJ, Lcvette
Time to create page: 0.236 seconds
