GCodeBackPlot issues
13 Nov 2020 19:28 #189244 by bcorley
GCodeBackPlot issues was created by bcorley
I am migrating from gtk/Glade to QtPyVCP and have some issues with the GCodeBackPlot widget.
I am using:
linuxcnc 2.8
Debian 9.13
pyqt5.7
#1. I would like to get rid of the grid lines in the zView
#2. The cone scales with the XY footprint of the loaded program. In Z view, on large footprint programs, it covers a large percentage of the cut path. Can I make it smaller and possibly translucent?
Thanks,
bcorley
The following user(s) said Thank You: tacklem60
15 Nov 2020 05:49 #189439 by tacklem60
Replied by tacklem60 on topic GCodeBackPlot issues
The grid lines can be spaces further apart (or removed entirely) in the ini file. Just change the grid increments and remove the ones you dont want or all of them to get rid of them completely.
As for the tool obscuring the toolpath when viewing from the Z direction, this is an exact problem i have been finding also and would love a solution to
15 Nov 2020 09:16 #189444 by tommylight
Replied by tommylight on topic GCodeBackPlot issues
Set the tool diameter in the tool table, i am pretty sure the GUI will change it's appearance depending on the tool dimensions and shape.
15 Nov 2020 10:39 #189447 by MaHa
Replied by MaHa on topic GCodeBackPlot issues
In my config in Axis 2.8 ,i was able to set under [DISPLAY] CONE_BASESIZE = 0.1 , to shrink the displayed cone
16 Nov 2020 14:19 #189513 by bcorley
Replied by bcorley on topic GCodeBackPlot issues
So, I commented out GRIDS under [DISPLAY] - no help, still shows grid lines. Was this the right parameter?
16 Nov 2020 14:34 #189514 by bcorley
For the cone size issue,
I added 'CONESIZE_BASESIZE=0.1' in my [DISPLAY] section - no help.
Could be that I am not using Axis, (I've made a custom GUI from scratch)? If so, what does Axis set based on this ini value?
Further, this is a plasma machine and I don't use the tool table. However, I tried sending an mdi of 'T1 M6', (T1 has diameter of 0.125" in tool table), but nothing changed. I cleared the program then reloaded it and the cone still becomes huge, ignoring the tool diameter set in the tool table.
16 Nov 2020 14:47 #189515 by tommylight
No pictures = never happened ! :)
16 Nov 2020 15:38 #189516 by bcorley
I attached a screenshot of the GUI. I was able to send an mdi of 'M61 T1' and the tool did change!
Now if I could just get rid of those pesky grid lines.
16 Nov 2020 17:28 #189524 by bcorley
sorry M61 Q1, not T1
06 Apr 2021 21:00 #205187 by sqmathlete
Replied by sqmathlete on topic GCodeBackPlot issues
I know this is a little late but I am thinking of doing the same with my custom lathe gui. How difficult is it to go from glade to QtPyVcp? Can you reuse your handler file in anyway?
Moderators: KCJ, Lcvette
Time to create page: 0.300 seconds
