Probe basic using override limits
5 years 5 months ago #210341 by Promo
Hi all,
Currently I'm trying to convert a BF30 to CNC using a 7i76e and linuxCNC with Probe basic.
During testing I would like to override the soft limits such that I can move the axis outside machine coordinates.
Probe basic has a 'override limits' option in the 'machine' dropdown menu but I can't select it. It acts if the button is greyed-out.
Do you know how I can activate the override limits function? Or is there a different way to move the motors outside of the machine-coordinates?
It might be a very silly question but it is all quite new to me.
Thanks for all the help!
The following user(s) said Thank You: Lcvette
5 years 5 months ago #210380 by andypugh
I have never used probe-basic, but on the GUIs that I have used the "override" button overrides the limit switches, and is only active when the switches are tripped.
You can (maybe) achieve what you want by temporarily changing the joint limits using the pins ini.0.max-limit, ini.0.min-limit etc.
5 years 5 months ago #210718 by Promo
Thanks for your help.
It sounds logical that 'override limits' is for when a limit switch is triggered. Maybe my understanding of the override function was just wrong.
That work around by changing the ini-file is handy! That's what I'll do.
Thanks again!
2 years 7 months ago - 2 years 7 months ago #297073 by Unlogic
Hi all,
This issue seems to still be there. I can't select the override option either.
Noticed this while setting up my limit switches yesterday. My workaround for now is to fire up Axis as the override option works there.
I'll create an issue on the Probe Basic GitHub page and see if any of the developers chime in.
Last edit: 2 years 7 months ago by Unlogic.
2 years 7 months ago #297097 by Unlogic
2 years 6 months ago - 2 years 6 months ago #297632 by Unlogic
I did some more digging into this issue and discovered there is actually two ways to trigger the "Limits override" function in Probe Basic.
One way is using the window menu (which doesn't seem to work), the other way is to toggle the button under the WCS tab on the right side and that way it seems to work fine.
Last edit: 2 years 6 months ago by Unlogic.
Moderators: KCJ, Lcvette
Time to create page: 0.258 seconds
