Probe Basic not working after udgrade to 0.4.0
4 years 5 months ago #242014 by nduerr
Hi TurBoss,
I am having this same issue, and I have tried the above with no luck. Is there something else that I need to add or change?
PS I have a 15 pocket Carousel, and would like to make or update the carousel picture file, Is there already a 15 pocket picture or where in linux can I find the stock ones to update?
Thanks,
Nick
4 years 5 months ago #242377 by Lcvette
the qml for the atc moving graphic can be adjusted for pocket count by simply setting the count in the ini file, see the above reference documentation on setting up the configuration files, it located in the sticky section, it shows the atc section and example of selecting the pocket count. once selected it automatically updates the graphic at launch for the correct carousel pocket count. defining the atc macros you will need to do to account for the new count.
CHris
3 years 6 months ago #269755 by CNCCustoms
Hi guys
Has anyone found a solution to this? My Installation has been working flawlessly for 6 months or so and then a few weeks ago this popped up. I ignored it and then it popped up again today and will not let me start Probe basic.
Help! :(
Thank you
Clint
3 years 6 months ago #269762 by Lcvette
need more info. the py2 version is not longer a working installer install because the installer broke. the best option currently is to upgrade to Debian Bookworm 12 and the latest version of probe basic installation via .deb file.
kcjengr.github.io/probe_basic/quick_start.html
Moderators: KCJ, Lcvette
Time to create page: 0.468 seconds
