(Solved) QtPyVcp in Python3.9 venv issues
17 Sep 2021 05:02 - 17 Sep 2021 05:09 #220873 by HarryXS
Hi at all,
I'm trying to install QtPyVcp on a Python 3.9.5 enviroment with all dependecies.
Now I'm stucked with:
from linuxcnc import ini ImportError: cannot import name 'ini' from 'linuxcnc' (unknown location)
importing linuxcnc works well.
This is strange...
Linuxcnc is Version 2.9.0~pre0
Thank you in advance.
Last edit: 17 Sep 2021 05:09 by HarryXS. Reason: added linuxcnc version
17 Sep 2021 05:15 #220874 by HarryXS
Replied by HarryXS on topic (Solved) QtPyVcp in Python3.9 venv issues
I think this is in the wrong subforum, it seems that it is a linuxcnc error from my side.
Please move it or delete it...
17 Sep 2021 09:18 #220898 by tommylight
Replied by tommylight on topic (Solved) QtPyVcp in Python3.9 venv issues
Leaving it a bit longer so please do report back.
20 Sep 2021 04:36 - 20 Sep 2021 04:40 #221182 by HarryXS
Ok, I tried to find out what happens.
- I freshly installed the linuxcnc 2.8 ISO from the buildbot.
- After that I installed qtpyvcp development for python3.
The same problem persists.
Python2.7:
OK
Python 3.7.3 (from the ISO):
import linuxcnc -> OK
from linuxcnc import ini -> FAIL
I thought they made a change in the import of attributes in Python3.8 but it does not work with 3.7.3 either.
I'll try to install the qtpyvcp Python2 version.
I don't think linuxcnc 2.8 will work without Python 2.7.
Last edit: 20 Sep 2021 04:40 by HarryXS.
20 Sep 2021 05:04 #221184 by TurBoss
Replied by TurBoss on topic (Solved) QtPyVcp in Python3.9 venv issues
Hello,
i think that the only way to setup a venv with linuxcnc
is build from source after sourcing the venv
linuxcnc.org/docs/devel/html/code/buildi...ing_for_run_in_place
$ source venv/bin/activate
$ git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev
$ cd linuxcnc-dev/src
$ ./autogen.sh
$ ./configure --with-realtime=uspace
$ make
# make setuid
20 Sep 2021 06:58 #221187 by BigJohnT
Replied by BigJohnT on topic (Solved) QtPyVcp in Python3.9 venv issues
Not sure how you installed 2.9 but you would need a very recent master branch for Python 3.
JT
24 Sep 2021 18:43 - 24 Sep 2021 20:37 #221522 by isaac
Replied by isaac on topic (Solved) QtPyVcp in Python3.9 venv issues
Last edit: 24 Sep 2021 20:37 by isaac.
24 Sep 2021 20:25 #221526 by TurBoss
if you built linuxcnc from sources
source linuxcnc/scripts/rip-environment
22 Oct 2021 07:39 #223912 by HarryXS
OK, after a long run I finally got it running on a Raspberry PI 4 4GB 64bit OS with the actual linuxcnc master and qtpyvcp.
I think it was too early as stated, with the recent linuxcnc master it works!
Btw. I managed to get gcodebackplot to run on the Raspberry Pi4 64bit with more than 60fps and V3D!
I'll share it with you as soon I cleaned it up and fix a strange bug after loading the gcode file, I'm not able to jog manually anymore...
I close this thread as solved
Cheers, Harry
22 Oct 2021 07:42 #223914 by HarryXS
Hmm, cant close the thread and mark it as solved...
someone a hint?
Moderators: KCJ, Lcvette
Time to create page: 0.248 seconds
