Probe Basic main screen doesn't show loaded toolpath
4 years 9 months ago #233680 by Lcvette
I suspect this is being caused by an update in linuxcnc. It is effecting the g and m code status channels also which are used in vtk backplotter. I have a machine that has not been updated for a while that is still running correctly and now one that is new with the issue. The branch that you installed has not been touched for a very long time and was working correctly until recently with no changes made to it. So their is likely a linuxcnc conflict happening is my best guess.
4 years 8 months ago #233805 by Lcvette
Ok after middling around trying to find the issue, it appears the status is broken in linuxcnc, can repeat issue on axis GUI and vtk pulls from status while loading the program file. So I suspect this is the culprit. Hopefully someone can resolve soon I am letting them know of the issue now in case it has not been reported.
4 years 8 months ago #234622 by dima_sz
Hello guys, I have been looking for a solution to this problem for a long time, I replaced the video card, installed another one but not Nvidia, now I don’t remember the exact model, but something from MSI, the problem disappeared. Try this way.
4 years 8 months ago #235473 by blauerklappstuhl
unfortunatly no possibility for me. using the pci for mesa and only having one on my mini itx board.
by the way: i updated(uninstalled 2.8.1 and installed latest) linuxcnc to 2.8.2 in the meantime, same problem as before :-(
4 years 1 month ago #251183 by blauerklappstuhl
found the issue with nouveau driver: need to deactivate acceleration in xorg.conf. :
Option "NoAccel" "True"
now i see loaded gcode.
The following user(s) said Thank You: Lcvette
4 years 1 month ago #251379 by Lcvette
That's great information, thank you for reporting!
Moderators: KCJ, Lcvette
Time to create page: 0.099 seconds
